I am trying to mill rather simple part with a outside profile and an open cavity in the center. Plunging from outside the stock.
I have tried setting the depth of cut from model top and stock top both and it shows -.760 depth on the simulation, but when the code is generated it shows in the code and on the machine as about +.2**
also with plunge checked I thought it would go straight to depth in stead of helical in.
Here is a copy of the start of the program. starts with tool 2 .375 em
Just learning but I haven't had this happen before.
Posting to Path Pilot .
Can't say what you have done as I don't use Fusion but these moves are all G01 interpolated so they will occur as 3 D moves. Also, the Z values are all positive (above the part but descending towards it):
