Hit a snag again :)
Page 1 of 4 1234 LastLast
Results 1 to 20 of 77
Thread: Hit a snag again :)
    Feb 2014
    United Kingdom
    Default Hit a snag again :)
    Must be my day for baffling Fusion things
    Two features to mill, nice easy selections, roughing out with a 2d adaptive path, two steps down for each feature.
    Now, WHY would fusion decide to do one pass then rapid to the other feature and do one pass then rapid back and so on - this makes no sense at all ?????
    Attached Thumbnails Attached Thumbnails Hit a snag again :)-screen-shot-2018-02-11-17-37-a
    Bending bits of metal in Hertfordshire - https://ddmetalproducts.co.uk
    Member precisionmetal's Avatar
    Oct 2010
    Default Re: Hit a snag again :)
    There should be an easy way to prevent that. Can you share your file?
    thx
    PM
    Feb 2014
    United Kingdom
    Hi
    Can't this time as it's not mine I'm afraid.
    I did fix it but only by splitting the path into two tasks, one for each hole. Not as tidy but works.
    Very baffling as nothing i tweeted made it do one then the other, it just wanted to hop between the two.
    Mar 2008
    This is just one of the bugs that HSMworks has. They have some work to do but it is just a minor inconvenience with air cutting. HSMworks started this on their own while other companies just buy the CNC technology from other companies and put it in their software.
    Community Moderator difalkner's Avatar
    Nov 2014
    I just drew a simple rectangle 3" x 4" x 0.5", created two pockets, two step downs of 0.25" each, and using 2D Adaptive I chose 'Order by area' and the toolpath completes one pocket before moving on to the other.
    Hit a snag again :)-003-fusion-360-order-area-jpg
    David
    David
    Romans 3:23
    CurlyWoodShop - www.etsy.com/shop/CurlyWoodShop
    David Falkner - www.youtube.com/user/difalkner
    difalkner - www.instagram.com/difalkner
    Feb 2014
    United Kingdom
    Thanks, it does seem to be the Order by depths that fixed it - it defaults to Order by islands and i hadn't tweaked those two settings before
    thanks again
  7. #7
    Feb 2014
    United Kingdom
    Hmm, ok i maybe going way too far ahead here
    I was hoping to run something like a 2mm ball-end fillet along the edge highlighted in the pic.
    Naturally, Fusion says no, warnings about the ends of the chain etc, my guess is because the ends blend into the main body?
    I'm not to bothered here as it's just me adding features to improve it- it won't affect the part if i don't bother
    Is this advanced?
    Thanks again
    Attached Thumbnails Attached Thumbnails Hit a snag again :)-screen-shot-2018-02-13-20-20-a
  8. #8
    Gold Member daniellyall's Avatar
    Sep 2009
    New Zealand
    That's something that needs work in fusion to make it better or give a error message
    <img src="https://ivxo1q-dm2305.files.1drv.com/y4mENMmTr_Cabc7pR0FUdB6gtbADq2JbuG4_rGy0eBQvLJx19pTi6TqMUIJN0xgOyDIc0gWoxYhS38HpbSTFGdfaK-o42IOU6jczrhDpfpCOTNGL1X6hvZCbgj0y35gqmq1YGTrWwShYGV-C7lXA2esy0Pi_WfnBSyroDLSGXwce4uSr1U7op7srdi78rispHCa_K4aFlTlJPVkkNWMfgh_Tg?width=60&height=60&cropmode=none" width="60" height="60" />
    Being Disabled is OK CNC is For fuN
  9. #9
    Oct 2010
    I did a quick test along these lines. Just a simple plate with a spline generated step. I modeled a .0625" radius in the corner.
    Op 1: Adaptive Clearing using a 3/8" end mill with a .020" corner radius
    Opt 2: A "2D Trace" path using a .125" ball end mill, and the second screen grab shows the edge/feature/line I selected, and the settings in the 4th tab.
    Worked perfectly.
    Hit a snag again :)-1-jpg
    Hit a snag again :)-2-jpg
  10. #10
    Feb 2014
    United Kingdom
    My issue seems to be in the modelling then, i could not add the fillet feature - this was where the error was coming in.
    In your test part the fillet rad is there, mine is still square
    I'll play some more.
  11. #11
    Sep 2009
    New Zealand
    did you try it with a fillet size above and below 2mm sometimes 1.99 or 2.01 works
  12. #12
    Feb 2014
    United Kingdom
    Yep, all way down to silly size, this is the error...
    Error: The fillet/chamfer could not be created at the requested size. This might be occurring at the ends of the selected edges.
    Try adjusting the size or using multiple separate operations. Check that the selected edge chain ends at a sensible position, and if not try selecting more edges.
  13. #13
    Sep 2009
    New Zealand
    Yer it's a errors error error. if you realy wont it in there do a sweep, or the other option is try a ruled fillet
  14. #14
    Feb 2014
    United Kingdom
    Hmm, rule fillet gives same error, no idea how to sweep so maybe i'll just leave it off this time
  15. #15
    Oct 2010
    Yes, in your model it's doubtful that Fusion would allow the fillet.
    You may be able to create a line on a sketch that is 1mm off that corner, then use that line to create your Trace path (on centerline). Or... simply select that (existing) sharp corner line on the model, and do an axial offset of 1mm after selecting in the Trace method.
    PM
  16. #16
    Oct 2010
    Here you go... I left the corner sharp, offset to the "Left" since I'm climb cutting, and extended the path off the ends.
    Hit a snag again :)-3-jpg
    Hit a snag again :)-4-jpg
  17. #17
    Feb 2014
    United Kingdom
    Perfect - the trace path will do exactly as i wanted
    Thanks all
  18. #18
    Feb 2014
    United Kingdom
    Just when you think your'e getting places, Fusion kicks you in the whatnots
    Here is a share link to the part i was hoping to add the fillets to, several hours later not only did i not get the fillets added, I cant even figure a strategy that works how i want it to ;(
    A360
    What i was hoping to do was machine the part from each side towards the centre-line from a larger lump of stock. I wanted to leave a frame of stock around it so i could flip it over and machine the back - it would be machined in a pocket basically. I can select the mid-line as a depth easily, but no matter what method i seem to choose, the paths either do not cover the whole perimeter or they cover the whole stock surface which means no pocket and side 2 would be seriously harder and likely need a fixture etc.
    When doing the back, i wanted to leave holding tabs so it didn't fall free.
    Not sure if that makes sense but i know what i want just not how to get it
  19. #19
    Sep 2009
    New Zealand
    It make sense it's a router users way of doing it, you see some machinist doing the same thing and they get very excited that it worked.
  20. #20
    Sep 2009
    New Zealand
    Just to be a smartass
    Hit a snag again :)-smart-arse-jpg
Hit a snag again :)
Hit a snag again :)
