Help with creating bracket in fusion
Results 1 to 4 of 4
Thread: Help with creating bracket in fusion
    Apr 2017
    United Kingdom
    Default Help with creating bracket in fusion
    Hi Guys
    Can someone help with designing a support bracket for my kress spindle?
    I need a bracket that will have support the kress on my cnc. i need the bracket to wrap around the part just above the on button but i am unsure how i can create the object to correctly wrap around the spindle.
    can i create a line that will follow the shape of the spindle? so the bracket can wrap around the spindle and secure it from the font and back.
    Attached Thumbnails Attached Thumbnails Help with creating bracket in fusion-kress-png
    Member precisionmetal's Avatar
    Oct 2010
    Default Re: Help with creating bracket in fusion
    Maybe...
    Create a construction plane at the point where you want your bracket.
    Use that plane to "slice" your spindle/model in half at that point.
    Then create a sketch and project the edges produced by slicing the part.
    Create your bracket model off that sketch.
    Or....
    Just create a body of the plate that you want to make, and leave it complete solid.
    Move the spindle "into it" in the correct location, and then use the spindle as a "cut tool" to remove/cut out the plate.
    PM
    Apr 2017
    United Kingdom
    Quote Originally Posted by precisionmetal View Post
    Maybe...
    Or....
    PM
    do you have an example of how to do this?
    Oct 2010
    Sure. Send me your email via private message and I'll send a short video of each method.
    PM
