I've rebuilt a YANG SMT500 and busy with commissioning it.
I'm new to the machine and never actually run it before.
The tool changer has 2 issues.
Stops mid code
Sometimes a loud crack when releasing the tool.
It does appear that setting G54 parameters upsets the process, but I'm hesitant to try too many options so as not to break anything.
Here is the Auto tool changer program
Code:
1 %
2 :9020(TOOL CHANGE MARCO)
3 M9 Coolant Off
4 G94 Feed Per minute
5 IF[#1015EQ1]GOTO50 Checking tools
6 IF[#20EQ#0]GOTO40 Checking tools
7 #106=BIN[#1032] Checking tools
8 IF[#106EQ#20]GOTO30 Checking tools
9 #1100=1 16 BIT PARAMETER
10 #101=#4001 System variables for modal information - G00, G01, G02, G03, G33 (Group 01)
11 #102=#4002 System variables for modal information - G17, G18, G19 (Group 02)
12 #103=#4003 System variables for modal information - G90, G91 (Group 03)
13 G17G91G80G0G49 XY Plane/Incremental Positioning/Turn Off canned cycles/Rapid/Tool compensation off.
14 M19 Spindle orientation
15 M86 Auto Door Close
16 M07 Air Blast
17 G1Z60.F4000. Move @ Feed to 60mm Rate 4000
18 G30Z0. Move Z to machine Zero point
19 T#20 I presume move to tool stored in memory #20
20 M07 Air Blast
21 G0Z-74. Z Rapid to -74
22 G1Z-60. Z Feed to -74, (Rate 4000 from above)
23 G28Z0. Zero return the tool to its zero position via a reference point at rapid speed
24 G#101G#102G#103 Reset parameters
25 #1100=0 16 BIT PARAMETER
26 M87 Oil mist/air blow ON
27 G90G95 Absolute dimensioning mode/Feed per revolution mode
28 N30M99 Return back to the main program
30 %
Line 17 Move Z to 60 mm Which reference is this ? Machine Zero or G54. It must be Machine Zero but where is the G54 disabled ?
Line 15 M86 - Is this maybe a canned cycle for the tool change ?
Is there a Fanuc parameter that is set to know if the coolant was set on or not ? Maybe M86 and M87 are those parameters.
