M6 tool change error
Results 1 to 4 of 4
Thread: M6 tool change error
    Member joesmith2022's Avatar
    Nov 2022
    Default M6 tool change error
    Hi All
    I have a 90s fanuc om controlled mill tmv400 having recently upgraded from a desk top mill. I am no expert.
    I am having trouble getting m6 to work.
    If I mdi m6 t1 I get a carousel error
    I have attached the error screen and the data about them from my manual.
    My tool change is a robodrill type 10 Station
    OK I can get round this by going
    M16
    G28 z0
    G30 z0 lifts spindle to second ref
    Then press my carousel button to the right station or
    M6 t1
    Then
    G28 zo
    So if in the G30 z0 position m6 works in terms of indexing to the correct position but it won't unload or load a tool.
    I have also attached 9001 program that I think is something to do with tool change.
    Any ideas or things to try appreciated. I'm pretty green.
    Cheers
    Dusty
    Sent from my CLT-L09 using Tapatalk
    Nov 2007
    Canada and Nothern ireland
    Default Re: M6 tool change error
    You can run the O9001 as a program so does it change a waiting tool for you ?
    When M6 is installed it can be ran through a macro program like that but needs to be declared in the parameter screen to do so ?
    pre call a tool to change position in the mag by
    T1;
    then run that program
    Flies Fast Superman's Avatar
    Dec 2008
    Antarctica
    What happens if you type T1 M6 ?
    Jan 2013
    england
    Quote Originally Posted by joesmith2022 View Post
    Hi All
    M16
    G28 z0
    M6 t1
    Then
    G28 zo
    Cheers
    Dusty
    the
    M code is missing a finish signal, usually from a switch, however if the M6 command isn't completed it will also give this alarm. The tool measure error code is interesting, do you have a tool length touch probe mounted, is it functioning ?
    Try single blocks through the program to see where the tool change program hangs up.
