Would be handy if you gave more information such as machine type and turret
need help!
pls help. My cnc Machine Turret Sensor not work. so how i remove it and replace it.
Is it 14/15T hall sensor in the four position turret?
If yes, then replace a new sensor could solve the problem.
Or if you are using it with Fanuc controller, you might need to add pull-up resistors.
You can refer to below page for similar issue.
14/15T Sensor for Fanuc Control
http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
