Update 2022:
There are 3 things to consider going forwards;
- Releasing plans for the tool carousel is futile. Everyone has a different machine and you would have to spend the time to figure it out on your machine anyways. Thankfully this is actually the easiest part!
- Tool carousels are for the most part adding another axis and homing sensor to your existing machine. If you have the space in your control box, add another axis and sensor and be done with it! Don't over complicate things!
- If you DO NOT have the space for an extra axis then you "may" be interested in my project for the controller software BUT any ModBus Axis controller will work. You can get them cheap on Amazon.
That said, what I do have complete and in final testing stages is a fully retracting ATC Tool Carousel for the AvidCNC PRO60120. It does NOT require the extended gantry but it does give more room to play with.
Here are the features of "ATC-10 for the AvidCNC PRO60120" as we are calling it;
- Laser cut components with some parts 3D Printed as a cost saving measure
- Complete self contained electronics package with ModBus over TCP/IP as the comms protocol
- Safety sensors for pneumatic ATCs, both running pressure and drawbar pressure (reduces wear and tear on your spindle when you forget to turn the compressor on)
- Shortest route, prompt and pause for tools not currently on the carousel (infinite tools with only 10 slots!)
- Retractable carousel leaves your full work envelope available for most sheet stock
- Fully automated dust shoe option will be available
TImeline for availability is April 2022.
