No apologies and no need for sorrow friend.
We all learn something.
The moment you recognize you don’t know something, is the very same moment you begin to know something. ????
It is true and you are right, Kelsang-Lungta.
in fanuc it is table of tools maybe yoiu want to take tool that doesn't exest in tool table?
Hurco BMC 2416
Can you take a photo of your control panel and attach it?
A message like that is going to be MTB defined. It would be in your manufacturer's error code books if you have them. To me that sounds like a physical sensor mounted on or near the tool carousel that counts the carousels individual rotational movements. This could be disconnected or have wet or broken wires or missing completely. To me this does not sound like a missing parameter issue but a control not getting the carousels movement information it needs to know what tool is in what position. It is confused.
Just my take on it.
What's funny in this situation is the MTB spelled Magazine wrong. Hilarious!
I noticed that it's possible to rotate tool magazine in manual mode (there are 3 proximity sensor mounted on tool magazine ).
I checked the three corresponding signals on the diagnostic screen and bits changed from "0" to "1" or vice versa for each proximity sensor.
Well bit changes like that pretty much shot my idea down.
Does it say anything in your books about the 2008 error code? If you do not have the books, have you also tried to Google search it?
I think you're soo close. Something is holding it up. Does this machine have a ladder you can look at? That should tell you something.
Running out of ideas.
...can get some photo;s of the I/O PCB board Cables plugs..etc,...maybe the MTB marked them with the M Codes for the TC or loose plug.......one more thing to check for is there an Encoder on the Tool carousel?
I have three, the connecting manual, operator's manual and maintenance manual, but incredibly there is nothing.
I tried with google, some first issues were solved. However, I did not find information about ATC issue for yasnac mx1 controller.
regard to ladder, there is also nothing in the manuals. This machine was manufactured around 80's. Maybe I will need assistance of a technician with experience in very old machines.
If you need new controller, I can offer my company's controller for you to finish your machine. https://www.weihong.com.cn/en/
isthisyour machine type config TC?
