- Chevalier Falcon 2040mv
I have a falcon 2040 that will not open the Colette far enough to get the tool in, the draw bar is not pulling it up into place.when i hit the button the piston goes about half way to the limit switch and stops.
the cylinder has a plastic oil feeder on the side of it looks like a bout a cup, are these air over oil?
Sure would be grateful for a clue on where to start. I have 100lbs of air into the manifold, the oil res is full.
- You may not post replies
- You may not edit your posts
Forum Rules
