- ATC issue, 2000 Clausing StingRay Machining Center
Hello everyone!
I'm a noob cnc user and recently I purchased a 2000 Clausing StingRay Machining Center with a Fanuc 0-MD controller. The machining was out of work for over 2 years, but gradually I've been able to make it usable again.
My current problem with this machine is that when I try to do an ATC it just doesn`t answer... I set the run mode select switch to MDI mode, key in M06 command and then Txx (xx = number of the tool) + insert + cycle start button and nothing happens besides a BUF message in which disappears in a haste...
Fun fact is that when I run an already saved G-code the machine is able to perform the tool changes perfectly... Anyone has any thoughts on what the problem would be?
- You may not post replies
- You may not edit your posts
Forum Rules
