Low cost ATC
Results 1 to 11 of 11
Thread: Low cost ATC
    Member WestyOne's Avatar
    Feb 2017
    Default Low cost ATC
    I wanted an ATC but Smithy didn't offer one for the MX200 Talon. The "Rack" type hogs some machining real estate so that had to go. Here's what I did. Easy.
    Attached Thumbnails Attached Thumbnails Low cost ATC-snapshot-jpg
    Smithy Automate MX200 mill, CNC Masters 1440, CWI Professor CNC Router, various other junk
    Jan 2016
    Default Re: Low cost ATC
    I like your ATC. Any video's of it in action? Looks like you are running a commercial grade controller and not Mach3 or PathPilot.
    Feb 2017
    Hi - If you click on the photo you will go to my web site where the video is. It would be easy to make this work with Mach 3 (easier than the Siemens controller).
    Cheers
    Jan 2016
    Very nice. I have a Novakon Pulsar and looking for a simple ATC. I am using PathPilot for control.
    Steve
    Feb 2017
    Do you have a power draw bar?
    Jan 2016
    Yes, I have a PDB similar to Tormach's.
    Steve
  7. #7
    Feb 2017
    What type of Tool Holders?
  8. #8
    Jan 2016
    Tormach TTS type tool holders.
  9. #9
    Feb 2017
    Should work perfect.
  10. #10
    Jan 2016
    Tim, are you using a work offset for your first tool location then offsetting from there for the other three tools?
    Steve
  11. #11
    Feb 2017
    Steve - In my application the Sinumerik 808D control has provisions for 4 "Fixed Position" variable sets (X,Y,Z). Each set is a tool pocket location. The Tool Change macro logic figures it all from there. Work offsets would work just as well.
    I assume you can orient the spindle on your machine.
    Bob J
Low cost ATC
Low cost ATC
