Aluminium Round, OD Grooved, through hole + c'bore - NSW
Results 1 to 2 of 2
Thread: Aluminium Round, OD Grooved, through hole + c'bore - NSW
    Nov 2017
    Default Aluminium Round, OD Grooved, through hole + c'bore - NSW
    Hi guys, is there anyone currently out there that can make 6 off these parts? Either from 6061 or similar material. The OD is 63.19mm. Details on the features in the description can be provided if needed, just after a ballpark figure of what it would cost. Would it be any cheaper if I supplied the material. Thanks in advance.
    Attached Thumbnails Attached Thumbnails Aluminium Round, OD Grooved, through hole + c'bore - NSW-img_1102-jpg
    Member konwey's Avatar
    May 2017
    China
    Default Re: Aluminium Round, OD Grooved, through hole + c'bore - NSW
    Hi,It can be cut into 6 pieces. I can cut it here by wire cutting machinesPlease contact me kon@cncmachining.cc
    Cheers!
    Over 15 year in cnc machining parts business.CNC Turning, Milling, Drilling, Planning, Grinding, Welding ./www.plusminusthree.com Email?kon@plusminusthree.com
