Just a thought have you got 5Volts on the enable pin of the steeper driver. I note you do not have driver enable pins selected in your setup on the axis page. When you jog are you getting the leds lighting up in the diagnostics window?
Hey G'day folks,
I bought 5 x DM556T Digital Stepper Drivers to replace my tb 6600.
My cnc was working with the tb 6600. I have an axbb-e and use uccnc.
Replaced the tb6600 with the 556s I get motor lock but no motion, uccnc behaves as if it were in demo mode but its not in demo mode. Checked license and my name is there. The numbers move up and down but stepper motors are silent not budging.
So what I've done so far.
1. I've unplugged the 556t's and put back 2 x tb6600's on x and z, nothing happening. Same deal numbers are working stepper motors lock but no motion. (which in itself is annoying as it was working with the tb6600's before the transplant)
2. Check and rechecked the wiring many times.
3. uninstalled and reinstalled uccnc.
4. reset axbb-e to factory defaults. The two green led's and blue in the middle both working.
5. checked power supplies both working.
6, power must be reaching stepper motors as they lock and cant move x or z manually.
7. got to a point where I was just staring blankly at the box scratching my head.
If anyone has any ideas or hail mary's I'd appreciate any advice.
Many thanks in advance.
Steve
I'm posting some pics maybe someone might spot something obvious or had a similar experience.
Ok,
I have a UCSB board on port 3 of my axbb-e which was running my B slave. Thought I would hook up x and z to that, I get motion..
So all I can conclude so far is that somehow my axbb-e is faulty?!?!?!
Have tested all my steppers they all work tested 1 x 1 through the UCSB.
Does anyone know if there is a diagnostics of any sort that can determine the status of the axbb-e?
Lights are working nothing seems to be out of the ordinary on the axbb-e, I would have imagined if the axbb-e was faulty the ucsb on port 3 wouldn't work either so I didnt test it earlier.
Any suggestions?
Cheers,
Steve
Hi curiosity22 please see attached settings and diagnostic settings of my CNC that I use with UCCNC ETH 300.
Hope you find these useful for your trouble shooting.
JIM
In your images it shows O10 port 1 red, this to me suggests e-stop pin (like a standard bob is set for) so.....
Just a thought.
Are you using the correct plugin?.
If not, normally breakout boards see pins 10 and 13 of port 1 as inputs.
This could be what it's doing.
On my 300, port 1 is input 2to13,15. Out is 1,14,16,17
Port 2 is output 1to9,14,16,17. In 10,11,12,13,15
The AXBB-E is based on the same board, however, I don't know how the plugin assigns it's I/O.
Hey Daz G'day,
TY for your posts its much appreciated.
I went and saw Peter at Homann yesterday and picked up some new units. Thankfully he allowed me to pick up on a Sunday. Both my units were fried so not much option left to me.
Cheers,
Steve
Lets see if I can get it right this time round, expensive mistake.
Hey G'day,
The enable pin, would someone care to explain what its purpose is. Daz has enable on his pics there. I don't, everything seems to be functioning now as its supposed too.
If someone could be good enough to explain if it is a requirement or leave well enough alone.
Cheers,
Steve
