Australia Melbourne - Bridgeport/Heidenhain Guru needed
Results 1 to 2 of 2
Thread: Melbourne - Bridgeport/Heidenhain Guru needed
    Member oz_eight6's Avatar
    Aug 2020
    Default Melbourne - Bridgeport/Heidenhain Guru needed
    Hi all,
    I'm knee deep in trying to fix my Bridgeport tool changer, the spindle encoder is on the fritz, some days it likes to play ball but mostly it wont.
    I have downloaded as many manuals and the like to try and understand how to diagnose the issue but im coming up short each time.
    Is there a guru in and around Melbourne who could either come and troubleshoot the issue or can walk me through the process myself.
    my machine is a Bridgeport VMC 1000-22 running on a Heidenhain TNC 2500 b
    Cheers,
    Adam
    Aug 2020
    Default Re: Melbourne - Bridgeport/Heidenhain Guru needed
    Had a great technician out today to trace the encoder signal,
    first off the machine
    Encoder signal goes to Heidenhain controller card no issues, signal can be seen from the pins on the control board. We can also see the analogue output from 0-10v which incrementally move up as the rpm is changed ie 500rpm = .5v 2000 rpm = 2v and inverse for counterclockwise
    this is seen at the simodrive analogue inputs
    seems the simodrive isnt seeing 0.0v as stop thinking maybe the simodrive is faulty
