Australia NcStudio VFD settings needed please
Results 1 to 15 of 15
Thread: NcStudio VFD settings needed please
    May 2007
    New Zealand
    Default NcStudio VFD settings needed please
    Hi all, after a long time away I have another machine.
    I am using NcStudio again because it served me well for years and was pretty much set and forget for me.
    The problem I have is I cannot work out the settings I need to select in the vfd to enable speed control using NcStudio. I have read the manual, searched high and low but have struggled to find guidance. The settings revolve around using SPL SPM & SPH.
    The vfd is a Huanyang HY02D223B with a matching Huanyang 2.2kw water cooled,spindle, NcStudio is 5.5.60.
    If anyone is using the same setup, would you mind sharing your PD settings with me please, I don’t want to take a guess and get it wrong.
    Thanks for reading this, any shared settings would be much appreciated. Also posted this in Chinese Machines hoping to cover all bases.
    Cheers Rob
    Jan 2005
    Default Re: NcStudio VFD settings needed please
    Quote Originally Posted by robbec View Post
    Cheers Rob
    The VFD Drive settings are as listed for the VFD Drive and Spindle SPL SPM and SPH These are not used for your setup
    What are the outputs from your control???
    Does it have a Relay output for the Drive if so this will be used to Turn On / Off
    PWM to Analog 0-10v Output, this is all you need to control the speed with
    Huanyang Mactec54
    2.2Kw 220v 400Hz Water Cooled
    PD000=0 ( 0 For Parameter unlock ) ( 1 For Locked )
    PD001=0 (1 For Remote Control)
    PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control ) ( J1 Also Needs to be set for Remote Terminal Control 1-2 jumper connection )
    PD003=400
    PD004=400
    PD005=400
    PD006=140
    PD007=20
    PD008=220 (Motor Rated Voltage )
    PD009=77
    PD010=11
    PD011=120 ( 100 Minimum Setting )
    PD13= 08 (is for Factory reset, Only use this to set VFD to Factory Default Settings )
    PD014=8 ( Acceleration Adjust to suit)
    PD015=8 ( Deceleration Adjust to suit) ( PD15 is ignored IF PD26=1 Then the Spindle will Coast to a Stop)
    PD023=0 ( Forward Run Only )
    PD041=8 ( Carrier Frequency up to 10 Max for these Spindle motors)
    PD120=120 ( Stall Prevention )
    PD141=220 ( Motor Rated Voltage )
    PD142=9 ( Motor Max Amps 2.2Kw Spindle 9 amp )
    PD143=2 ( Motor Number of Poles)
    PD144=3000 (Max Motor RPM) 3,000= (24,000)
    PD070=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
    PD072=400
    PD073=120 ( 100 Minimum RPM Setting )
    PD174= ??? ( To Be Set to the VFD Drives Max Rated Output Amps )
    Note if PD011 and PD073 are changed then PD06 and PD09 will have to be reconfigured also
    Mactec54
    May 2007
    New Zealand
    Thumbs up Re: NcStudio VFD settings needed please
    [QUOTE=mactec54;2452534]The VFD Drive settings are as listed for the VFD Drive and Spindle SPL SPM and SPH These are not used for your setup
    Thanks for the reply mactec54
    From what I know I do need to use the spl spm sph inputs to control speed, these are the outputs on my bob.
    Pd047, 48 & 49 as well as Pd086, 87 & 88 are what I need to use from the limited info I can find but not 100% sure on all settings hence my post.
    Again, thanks for the reply.
    Jan 2005
    [QUOTE=robbec;2452662]
    No you don't need to use them, you control has a 0-10v Analog output that is all you need for the speed control
    Which of these do you have for connections
    SVC ???
    AVC ???
    GND ???
    C00 ???
    Y00 ???
    Mactec54
    May 2007
    New Zealand
    Are you referring to the bob?
    If so, it only has a GND connection from the connections on your list, non of the others.
    This is the bob I am using, the three red lines indicate the spl spm sph connections.
    NcStudio VFD settings needed please-4d2c18aa-e627-4ba8-9ee3-2197f7c33bef-jpg
    Jan 2010
    united states
    I just rewired an older camaster that had nc studio. It used 4 wires to the spindle and had 3 set speeds. One wire was the activation wire and touching that wire to each of the other 3 turned it on and ran it at those speeds. Yours may be different, but that's how this one was.
  7. #7
    Jan 2005
    You would be better off using Mach3 than that setup which is not very good what is the Main NC Board model #
    53C ??
    95A ??
    With that Breakout Board you have no choice, that is a very poor example of a Breakout Board it has no opto isolation
    Attached Thumbnails Attached Thumbnails NcStudio VFD settings needed please-breakout-board-2-png
    Mactec54
  8. #8
    May 2007
    New Zealand
    Thanks for your input guys, I understand what I was trying to achieve was not ideal but it was going to be easy for me.
    Anyway, when I bought my machine it came with a Grbl based controller which I didn’t really want to have to learn about but I now am.
    It’s a Spark Concepts xPro v5, starting to get my head around it. It has a couple of output methods for spindle control so presently just trying to work out which to use then will need to find vfd settings.
    Will update this once I have success.
    Again, thanks for your input.
  9. #9
    Jan 2005
    If you want to connect it with those 3 wires then you need to setup Parameters
    These numbers may be different for your VFD Drive as there is some other options, this will give you a starting point though
    A Ground or Com connection is also needed so 4 wire and you will have a set 3 speed not ideal but a starting point
    PD047=17
    PD048=18
    PD049=19
    PD080=1 it may be 2
    PD086=120
    PD087= 140
    PD089= 400
    These may also be in a different order with your VFD Drive but with the same numbers though
    If you have a 0-10v output then there is another way to do it that will give you any set speed you want, so if you can check your outputs by testing with a meter if your 0-10v output changes when you use your control in MDI mode do a M3S6000 or a M3S12000 = around 5v if you see this happening then there is a simple way to connect to the VFD Drive
    Mactec54
  10. #10
    Jan 2005
    So I just checked with the Spark Concepts xProv5 it has a PWM 0-10v output so that is an easy setup if this is what you are using that can be as simple as just 2 wires connected to the VFD Drive
    If it has a Relay somewhere that will be even better there are work arounds if it does not have a Relay
    Mactec54
  11. #11
    May 2007
    New Zealand
    Your a legend mactec54, always replying like this is very much appreciated. This whole vfd setup thing is becoming a very very steep learning curve for me, once up and running I will be back in a more comfortable place.
    Hopefully I am correct in that:
    The xpro 0-10v would connect to the 10v connection on the vfd
    The xpro GND would connect to the ACM on the vfd
    NcStudio VFD settings needed please-vfd-1-png
    There is an onboard relay, it puts out a 24V VFD logic signal according to the controller specs.
    Not sure where to connect this to on the vfd yet.
    NcStudio VFD settings needed please-vfd-2-png
    Will start looking through the vfd Pd setup now and see what I can come up with. Looking through the settings you provided above, would I just need to change PD001 to 1 & PD002 to 1 and the rest would be ok?
    Cheers
  12. #12
    May 2007
    New Zealand
    Update on my very steep learning curve.
    mactec54 - just realised that he xpro 0-10v would need to connect to the VI connection on the vfd not 10v.
    Also realised the relay output NO would connect to DCM on the vfd & the relay GND/COM would connect to FOR on the vfd.
    I am pretty sure i am heading in the right direction with this but would definitely appreciate your input to validate what I am learning is correct or if you believe there is a better way.
    Cheers
  13. #13
    Jan 2005
    Cheers
    You will need all the Parameters set that are in the list if your spindle is 400Hz
    Yes not far away FOR and DCM for the Rely to VFD Drive connection ( Now the Relay output to the VFD Drive can not have a Voltage on it, so check this before you connect it ) this is just a Switch so be careful with this
    For speed control VI and ACM Analog 0-10v output for your speed control ( again this needs to be checked with a meter to see that it is changing with a speed command before connecting it to the VFD Drive )
    VFD Drive J1 Jumper will have to be in the right position for Remote control to work also
    PD001 and PD002 plus the J1 Jumper is normally the only change needed for Remote control, sometimes there is another Parameter also that may need changing but do this first
    If you have the Spindle setup and running with the KeyPad this is best to test before you go Remote, as once you go Remote the Keypad will not work only the Stop button is active , you can still change modes but no Start function
    If the 0-10v is not working then you will have to use the PWM 0-10v output
    Mactec54
  14. #14
    May 2007
    New Zealand
    Thanks again, will look at this again tonight and try, feeling more confident now that I am starting to understand this.
    Cheers
  15. #15
    May 2007
    New Zealand
    Update.
    All working as expected, thanks for the advice, I actually got a reasonable understanding of the process in the end.
    Now on to the next problem
    Cheers
