Australia CNC Router Machine - Z axis stopped working
Results 1 to 8 of 8
Thread: CNC Router Machine - Z axis stopped working
    Question CNC Router Machine - Z axis stopped working
    Hey All,
    My Z axis has stopped moving.
    Stepper controller LED turns red from green when I try to use Z axis...
    What would the most likely fault be - stepper motor dead ?
    Worked fine yesterday.
    X & Y work just fine.
    David
    Attached Thumbnails Attached Thumbnails CNC Router Machine - Z axis stopped working-20200712_121242-large-jpg   CNC Router Machine - Z axis stopped working-20200712_114739-large-jpg
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Default Re: CNC Router Machine - Z axis stopped working
    Hi Fletch - Give all the wires a wiggle they do come loose sometimes. Then swap the motor plug to another drive if possible and see if same fault occurs. That will tell you if the motor is the issue or the driver side. After that things get complex. Peter
    Seems the motor bolt has come loose or wasn't done up right? see image
    Attached Thumbnails Attached Thumbnails CNC Router Machine - Z axis stopped working-bolt-jpg
    Perfect advise Pete ! I plugged it into my Y controller and it worked fine... Seems Z Microstep Driver M542-05 is faulty.
    Now to find a new one locally.,
    Thanks for your help
    Cheers
    Dave
    Attached Thumbnails Attached Thumbnails CNC Router Machine - Z axis stopped working-20200712_134828-large-jpg
    May 2015
    Quote Originally Posted by fletch123 View Post
    Cheers
    Dave
    Dave, if you get stuck, I have a few Longs Motors DM542A drivers here in Brisbane as I upgraded my machine to validate an engineering model a mate created. The drivers are similar spec to yours, nothing wrong with them. Send me a PM. I can ship anywhere.
    Rod Webster
    www.vmn.com.au
    Quote Originally Posted by rodw View Post
    Cheers Rod, I ordered a couple from China the other day, they just shipped via DHL so I shoudl have them soonish.
    Member Sterob's Avatar
    Jan 2007
    Cheers
    Dave
    Just be aware Dave , that all you have done is prove the Z Axis motor ISN'T faulty. You haven't actually proven the Drive is the problem.
    You might be lucky...we will see.
    More testing would be required. If you can, try swapping the control signals to the drive , ie swap Z with X or Y. Same fault or different?
  7. #7
    Quote Originally Posted by Sterob View Post
    Thanks for your advise Sterob -
    Yep, that's exactly what I did. I swapped the control signal from the Z axis into the Y axis and it worked. Moved it back and it didn't. Fairly confident I should be set replacing the Z Microstep Driver.
    I'll post results here when the replacement unit arrives.
    Cheers
    Dave
  8. #8
    My replacement board arrived today, 10 minutes swap over and Z axis is working perfectly again
    Cheers
    Dave
