I think you misunderstood what I said, the linear rails when you buy them com in different Preload levels most get a medium preload, is they are preloaded then the rail mounting have to be near zero for straightness in all directions or they will wear quite quick
If the Linear Rails bearings have no Preload the your rail mounting does not have to be perfect it can be within the tolerance of that Rail Bearing set
