Originally Posted by
curiosity22
Olf G'day,
Just a quick update and thanks again for your assist. The debounce filter that I had no clue about nor what its use was for helped me further debug what was going on with my limit switches.
So earthing was ok, switches ok, replaced cable with shielded cable. My Y Axis was still doing a small samba dance of its own.
So I ended up putting on another limit switch on the opposite end of Y Axis, I have two steppers driving Y. I read somewhere on this forum that you needed to use a separate input if you want to auto lvl your gantry.
Neways, as soon as I hooked up the second limit switch for homing for the Y Axis, the Y on homing started performing the way it should. I thought maybe a coincidence so I disabled the second Y limit switch and Y Homing went back to doing a dance.
For whatever reason having Y Homing on the one limit switch with two steppers for me would not behave as it was meant too.
My problem is resolved back off works correctly, homing now ok, and I have removed debounce which is no longer required.
I'm sure it is due to operator error, I haven't done something properly somewhere.
For the moment everything is working correctly now.
Cheers and thanks for the assist.
Steve
