Coolant to mix with water for Fogbuster
Results 1 to 3 of 3
Thread: Coolant to mix with water for Fogbuster
    Member Sterob's Avatar
    Jan 2007
    Default Coolant to mix with water for Fogbuster
    I usually use Kero in a squirter bottle when machining Aluminium, but since I bought a Fogbuster I have just been using water.
    I think I would get better results if I could find a water soluable coolant to use in the Fogbuster.
    Anybody know if anything available in Australia, that works well? I'd use kero if I could get it to dissolve in water...lol
    Steve
    Apr 2008
    australia
    I think i've read a few guys use metho and water so its what i have just started using in a spray bottle and i'll use it when i get my cheap coolant mister up and running.
    Jan 2007
    Default Re: Coolant to mix with water for Fogbuster
    Thanks Tiller, Does the Metho help with machining or just cooling?
    I sent an equiry to Unist Australia, but being so close to Xmas not replay yet....
    https://unist.com.au/solutions/metalworking-fluids/
    Had another look around their website and it appears that their 2210AL Coolant my be the ticket.
    Will see what they say.
    Jun 2010
    Metho is a known lubricant for machining aluminium.
    You may be advised to walk home rather than drive at the end of the day though!
    Me, I use 3 parts kero : 1 part olive oil in a pulsed MQL system, with air blast. Short pulses rather than a continuous stream. A small bottle of the mix lasts for AGES. And the oil is bio-compatible. The kero evaporates away.
    Cheers
