Sieg X3 - Erratic Spindle Speed
Results 1 to 5 of 5
Thread: Sieg X3 - Erratic Spindle Speed
    Aug 2012
    Default Sieg X3 - Erratic Spindle Speed
    My X3 has developed very erratic stop/start motion at low motor speed settings and has no power to do any work. Opinions - motor, control board or speed control potentiometer?
    Member phomann's Avatar
    Aug 2005
    Default Re: Sieg X3 - Erratic Spindle Speed
    If it is DC motor with brushes, check the condition of the brushes by removing them and have a look. They may be worn or dirty.
    Cheers
    Peter
    Sent from my iPhone using Tapatalk Pro
    Homann Designs - http://www.homanndesigns.com
    Member rcheli's Avatar
    Nov 2005
    You may find some useful info at the link below on the trouble shooting page. Although checking the motor brushes as phomann said is the first thing I would do.
    www.olduhfguy.com
    May 2015
    I've had this problem with a SX3. unplugging connectors and wiping down with Innox fixed mine.
    Rod Webster
    www.vmn.com.au
    Aug 2012
    Thanks all for your replies. I have checked the brushes and they seemed fine but the commutator looks a bit ordinary. Its like the machine has a broken wire or similar with stop-start-stop-start action and it seemed to happen all of a sudden. I guess I'll check the connections and pull the motor and get a little more serious. I have a bit on my plate at the moment and was just trying to 'short circuit' the repair as its annoying not having the drill for quick little jobs. Thanks again.
