Australia Before I put power to micro step driver I need to confirm what gnd and vcc are please
Results 1 to 9 of 9
Thread: Before I put power to micro step driver I need to confirm what gnd and vcc are please
    Default Before I put power to micro step driver I need to confirm what gnd and vcc are please
    Hey G'day guys,
    Before I put power to this microsstep driver its juts a TB660.
    Can I assume that by GND they mean the minus and not actually earth?
    VCC is the positive?
    So from power supply I would minus to GND and Plus to VCC?
    Am I on the right path?
    Would prefer a none smoking smoldering path.
    Cheers and thanks in advance..
    Steve
    Member phomann's Avatar
    Aug 2005
    Default Re: Before I put power to micro step driver I need to confirm what gnd and vcc are pl
    Hi Steve,
    Yes that sounds correct. GND is used quite often to identify the negative side of the power supply (-ve) rather than Earth.
    Cheers
    Peter
    Sent from my iPhone using Tapatalk Pro
    Homann Designs - http://www.homanndesigns.com
    Aug 2005
    Also VCC is the power supply positive (+ve)
    Cheers
    Peter
    Hey Peter G'day,
    Thank you for clearing that up for me much appreciated.
    I can proceed then without melting anything.
    Cheers and avagreatday,
    Steve
    One other question please...
    I'm putting together my axbb-e I've never used a stepper controller before is why I'm asking.
    In the axbb manual I see step+ step- Dir+ Dir- the TB660 has ENA + ENA - (I'm assuming they are not used. Then DIR+ DIR- and PUL + PUL - I am assuming the PUL is the equivalent to the step as per axbb diagram? All the STEP and DIR - are wired to the 5V0.
    cheers and ty in advance.
    Steve
    Aug 2005
    Hi Steve,
    Usually 5V0 means 5.0Volts. But, on the Axbb-e it is the 0V for the 5V output. So yes you are correct. The STEP- and DIR- should be connected to the 5V0 terminal.
    Cheers
    Peter.
  7. #7
    Quote Originally Posted by phomann View Post
    Hi Steve,
    Cheers
    Peter.
    Peter ty again - I take it the pull +/- on the microstepper is the Step +/- on the axbb diagram?
    Cheers
    Steve
  8. #8
    Aug 2005
    Yes, that’s correct.
    Peter
  9. #9
    Cheers,
    Thought that may be the case..
    Regards,
    Steve
