Opinon Does anyone own one of these 5/6 axis controllers?
Results 1 to 11 of 11
Thread: Does anyone own one of these 5/6 axis controllers?
    Jun 2013
    Default Does anyone own one of these 5/6 axis controllers?
    Before I go trying to slave two steppers to one output on my Gecko thought I'd look around for 5 axis controllers, fell over these.
    Anyone own one of these? Dare I say they are cheap, cheap enough to try?
    Anyone like to proffer an opinion?
    https://www.lollette.com/NVCM6V2.1-CNC-Controller.html
    https://www.ebay.com.au/itm/NVCM6V2-...UAAOSw5HBbMMQf
    I think this is the same company
    https://www.ebay.com/itm/NVUM-5-Axis....c100005.m1851
    Cheers,
    Steve
    Jun 2010
    Default Re: Does anyone own one of these 5/6 axis controllers?
    Two words of caution:
    'Cheap' from China does not carry a lot of confidence.
    Some of these cheap Chinese motion controllers only handle g0, g1, g2, g3 and a few other simple g-code commands. They do not handle things like probing.
    Lollette site: $120 reduced to $46. Um ......
    Cheers
    Roger
    Jun 2013
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    Cheers mate,
    Steve
    Jan 2005
    Quote Originally Posted by curiosity22 View Post
    Cheers mate,
    Steve
    Get Ethernet if you are looking at these a little more money but worth it, also higher Hz output https://www.aliexpress.com/i/32836375806.html
    Mactec54
    Aug 2014
    I haven't used those devices, but sadly have some experience of repairing cheap Chinese offerings over the years. Usually things look good from the outside, apart from the usual spelling mistakes, but inside is a different matter. Everything on the board will be made very cheaply, they save a tiny fraction on whatever they can, and this will show most on the bits you get to touch like the connectors which will have the minimum amount of metal required to make a connection. Not good for reliability.
    Also, if a manufacturer prints "Enternet Controller" on his product, how carefully has he debugged the firmware ? Done thermal tests ? Noise immunity ?
    I've given up with cheap Chinese stuff now, preferring to buy old kit from reputable makers instead.
    Jun 2013
    Thanks for the info people, much appreciated.
    Cheers,
    Steve
  7. #7
    Jan 2005
    Quote Originally Posted by Zorbit View Post
    And who would be a good supplier,that you would suggest for someone to buy a Control Board from
    There is nothing wrong with this manufacture and they make a quality control Board
    Mactec54
  8. #8
    Aug 2014
    I just bought some boards from Mesa, they seem good quality.
    Mesa Electronics
  9. #9
    Jan 2005
    Mesa Electronics
    I don't think they will work to well with Mach3 and Gecko drives
    Mactec54
  10. #10
    Aug 2014
    My next build is LinuxCNC, my redundant Mach3 build uses https://warp9td.com
  11. #11
    Jun 2013
    Thank you for your interest people.
    Cheers,
    Steve
    I have ended up placing an order for a AXBB-E ethernet motion controller and breakout board combo.
    Cheers...
