Australia Designing new Router called Maximus - Page 3
Page 3 of 8 FirstFirst 123456 ... LastLast
Results 25 to 36 of 91
Thread: Designing new Router called Maximus
  1. #25
    Jan 2008
    Default Re: Designing new Router called Maximus
    Much better. I actually wrote part of a post earlier today suggesting you use perpendicular stiffeners (but on the go and didn't have time to finish it).
    I recommend you use an 80mm spindle. Besides being superior to a standard wood router, out makes it much easier to design a stiff Z carriage. You can make the whole thing into a box section pretty much.
    I think your actual gantry shape is overcomplicated. How are you going to fabricate it? Cost to do so? Why not just use a big bit of standard square hollow section (with bracing webs at regular intervals inside and end caps)?
    7xCNC.com - CNC info for the minilathe (7x10, 7x12, 7x14, 7x16)
  2. #26
    Dec 2003
    East Anglia,England
    I can see an area that might cause issues in the future and it often occurs with machines that are intended to have a fairly high gantry for Z axis clearance.You may struggle to get all jobs done that will fit under the gantry as the corners of the spindle mounting plate may foul the job-it really spoils your day when that happens.Could I suggest working out the angle of the sides of the "valley" that you will be able to work within? Its worth doing this in both directions as they are likely to be different angles. I hope you don't mind that I'm from the other side of the world and wandering into your area!It is an area of interest for me as I have spent lots of time with a plane and spokeshave shaping rudders and now I know that I can get a machine to move under it's own power a suitably sized machine beckons.
  3. #27
    Activation process peteeng's Avatar
    Jul 2018
    hi Pippin - Having it laser cut and bent is straightforward. My machines are designed for production kits to sell to Makers. If you use SHS you have to drill and tap many holes and generally you have to weld it and it distorts. If you do it the maximus way it's assembled easily with nuts. A nut is much cheaper then a threaded hole. You say use bracing webs inside. This is impossible to do in an SHS and being thick walled it is also unnecessary. For this machine a 250SHS 6mm thick would be needed and that would be way too heavy for this machine as intended.
    A note on design. The gantry rail spacing is a "found" spacing. It is the distance required via the vertical stack height of the Z Axis assembly. It has not been chosen or driven by a SHS size. So by bending metal sheet it is the "correct" size for the job. Also I can vary the front and back sheet thickness saving weight yet acheiving the performance.
    An 80mm spindle has always been the best solution for this size machine if you can afford it. I think I'll bite the bullet and design it as a full sheet machine. But the people that I talk to and aim these routers/lasers/plasma/food extruder etc at, are always looking for a cheaper solution and generally start with a Mikata or a Ryobi etc. Scoot my 1/2 sheet machine has a Makita barrel router that I have thrashed for 2 years and it's still cutting fine, just have to wear muffs. Thanks for participating Peter
    At the end of the Maximus design process (maybe Round 4 end) this machine will be costed completely and interests in buying determined. Typically I have to get three or 4 sets of parts made to get to minimum order requirements for a production run. So if anyone wants a full sheet cnc router kit its on its way, stay tuned.
  4. #28
    Jul 2018
    Hi Routalot. Welcome down under !! I suppose we are -Z. Yes the square bottom does hit things occasionally. My 1/2 sheet Scoot has a similar blunt end and it does catch stuff (including lots of dust) if you don't think ahead. Maximus is being developed as a kit, so stay tuned for final costing. I have intended to a) have the spindle stick down quite a bit or b) angle the edges of the Z Axis plate as much as possible. We are in Round 1 of the design and this round gets the concepts, geometry and limitations understood. So your comment is noted and will be addressed in time. Also to solve this issue, you can use longer tooling. But I have not found a supplier yet. There are lots of videos of robots and 5 axis machines with long tooling. I may have to make tool extensions for deep cavities. I had a client some years ago that had a Z500mm 3 axis mill and they made 400mm extensions for their tooling but did not do it quite right. I was there when a tool decided to whip and break not pretty!!
    Just over 2.5 years ago I was hand shaping a daggerboard for a trimaran and said, that's the last one I'm going to do!! If you search for Scoot cnc carbon-works you will find its blog.
    Peter
    3-04-19 added a chamfered bottom just for you Routalot. Its 50degs. Its not quite doable on a laser as built here but the feature is now captured and next time around I'll do it so it is laserable (if that's a word)
    Attached Thumbnails Attached Thumbnails Designing new Router called Maximus-plate-1-jpg   Designing new Router called Maximus-plate-2-jpg
  5. #29
    Jul 2018
    Good Day out there - Been looking at the parts as they stand and looking for any improvement of stiffness or cost part by part. Made a tweak here or there and some mental notes for Round 2. I also did some weight reduction efforts. The current all steel assm weighs 48.6kg and deflects 0.18mm under the nominal 100kgf load. I converted the front plate of the gantry then the rear plate to aluminium. These are the biggest parts in the assm. This brought the weight down to 30.6kg, an 18kg saving. The deflection grew to 0.32mm which I'll live with at present. I can make the back plate thicker and add the internal shear webs to improve this. 18kg extra is a lot to push around so we'll go with the aluminium at the mo.
    The current Z travel is 205mm which is the same as Scoot. Wanted 250mm but this will depend on the final stiffness of the machine. Haven't had to need more Z on Scoot in 2 years so 200mm maybe OK. The only time I had trouble was after a Z Axis rebuild and I put the router bracket on upside down. After that my gas strut that I use to hold the Z up kept bottoming and this never happened before. A quick look found the problem and it was fixed quick sticks.
    Peter
    The front plate in Al (5mmt) weighs 4.41kg and the rear in Al weighs 4.7kg (3mm t). In steel they would be 7800/2700= 2.89x heavier
    Attached Thumbnails Attached Thumbnails Designing new Router called Maximus-maxi-jpg
  6. #30
    Aug 2004
    spain
    Fwiw..
    sorry to be so negative.
    For cutting alu efficiently you need about 10x more stiffness.
    Look at the haas router for inspiration, it is the same size, grx series iirc, now discontinued.
    Belts wont work.
    Example, experience:
    I used 30 mm wide HTD-8 belts, and they are useless for rigidity.
    My spindle motor mount is 60 kg in mass in steel, 30 mm thick steel posts. 20 mm thick tool steel plates.
    The belts are simply much too bendy.
    Forget loads/capacity from linear guides.
    You want about 50x the capacity vs your working load.
    Every lathe/mill in the world is like this.
    My mill has 50 tons capacity in z, 35 mm linears, for a working load about 1 ton.
  7. #31
    Jul 2018
    Hi Hanermo - negative input is as good as positive here - I am designing a small kit router not a mill. If I wanted to build a mill I would buy a second hand manual mill CNC convert it or I would contract the parts that I wanted to a machinist with a big mill like I do now. I totally agree a Mill is a very different animal. BUT cutting aluminium is possible with a Maker grade router but not in the production oriented utility sense like you are in. That's why mills exist. For a hobbyist, Maker, DIYer cutting the occasional aluminium part on their router is a plus. I get asked all the time can this be done and the answer is yes with some provisions, limitations and understanding. I agree belts are not as rigid as screws or racks but the price point I'm aiming at can't bear the cost of these unless I find a cheaper supplier. This machine is not intended as a commercial production oriented machine like a HAAS or your several tonne machine, it's a <$4500AUD build so comparing it to these is a little unfair. I'd prefer to use helical racks but they are 4x the price of the belts. Everything in this design has to be honed down to the best price/performance point ratioed to the linear bearings cost. Otherwise we are in construction extrusions, belts and wheels territory so may as well buy a shapeoko or Ox kit or similar. Hope to keep you entertained... Peter
  8. #32
    Jul 2018
    I'm back at the start deciding if it's time to rebuild the CAD model. One initial design premise was to gain 20mm in space by making an odd shaped Z Axis plate. I'm thinking is this worth it? I'd like to have the spindle line up with the gantry bearings and this helps. But It also creates 60mm in extra width with the bends and limits the real estate to bolt on spindles and things to the gutter width. I think the other elements are pretty good at this stage. So the mantra "stiffness wins" needs to be applied to the gutter plate. So I need to model a straight one to compare it to. So perhaps a flat aluminium plate, a simple bent plate and the gutter plate to make the decision. Peter
    Attached Thumbnails Attached Thumbnails Designing new Router called Maximus-bearing-jpg   Designing new Router called Maximus-gutter-jpg
  9. #33
    Jul 2018
    Hi All - I modelled the three options. 1) the gutter design weighs 7.7kg in 8mm SS and deflects 0.07mm under 100kgf 2) I started with a 25mm thick al plate but it deflected heaps so went to a 30mm plate. It deflects 0.11mm and weighs 6.2kg 3) The straight 8mm SS plate of same depth as the gutter plate 70mm deflects the same as the gutter plate 0.07mm and weighs 8.9kg. So now I have to weigh up the pros and cons of the gutter vs the plain design. More thinking. I think I'll use the plain design and move onto Round 2. Can come back to the gutter design if needed. Which is detailing the parts and adding the motion parts. Peter
    Attached Thumbnails Attached Thumbnails Designing new Router called Maximus-comparison-jpg   Designing new Router called Maximus-capture-jpg
  10. #34
    Jul 2018
    For some time I have been wondering about how to model the compliance of the linear bearings. The thesis link has given me the correct path. Usually a bearing is modelled in steel and the connection stiffness is therefore overestimated. By modeling the bearing as a steel block and a compliant block at the contact we can get this right if we know the stiffness of the bearings. Turns out that the compliant bit needs to be about 6GPa. So in Round 2 I'll model the bearings as a two piece unit so I can include this. Manufacturers of bearings publish their stiffness so the model can be tuned to the correct compliance. That thesis is a good read.... Peter
  11. #35
    Aug 2014
    Interesting work, thanks. Are your deflection figures an average of the deflection in all directions ? Also, can your software simulate resonance in the Z plate ? I wonder if the solid ally plate might damp it better.
  12. #36
    Jul 2018
    Hi Zorbit - The deflection figure is the maximum distance from its starting point. I can image it in X,Y or Z if required. I can figure the modal frequencies of the assemblies. I just tried to solve the 3 assemblies in one model but there are too many directions of freedom for the solver to handle so have had to solve it in two goes.
    Summary
    The Gutter design first vibrates at 319htz, this is a torsional vib. Then it vibs at 553htz in a pendulum sort of way. The aluminium vibes as a cantilever at 541htz (same mode shape as gutter at 553htz). The plain design vibs at 290htz then 435htz. I may stiffen the plain design with a web or use the gutter design not sure yet. Next design round is to add more detail to the parts like bolt holes and start adding the motion components.
    There is a misconception out there that steel increases vibration somehow. This would fall into the "free lunch" category of which there is none. Steel is damp just not as damp as other materials. From the chart you can see that steel is 60% the dampness of cast iron and about 1/10 as damp as granite. The modal analysis calculates the free vibration frequency. If the material had no dampness it would vibrate at this freq forever once excited. But since materials have dampness this vibration settles out fast unless it is reinforced by some force input such as a tool load or inertial load. In another thread damping is discussed and I have put forth the idea to use laminated metals with thin rubber interlayers (or epoxy them together) to create a damp material. Search for damping to follow that up if interested. Laminated metals are used in aircraft for various reasons. Look up GLARE an aluminum laminate that Airbus makes its fuselages out of. Peter
    Al vs steel damping - From the chart you can see that Al is less damp then steel. This is because Al is locked up internally more than steel is. Steel has a cubic grain structure which has lots of slip planes for movement. Look at a brick wall and you can see how all the horizontal joints could slip easily. This is why steel forms so well. Al has a hexagonal grain structure so has very few slip planes. For it to slip it has to climb up and down the hexs so it's quite stiff internally. So steel is better from a material damping point of view.
    Attached Thumbnails Attached Thumbnails Designing new Router called Maximus-plain-290htz-jpg   Designing new Router called Maximus-aluminium-541htz-jpg   Designing new Router called Maximus-gutter-torsion-jpg   Designing new Router called Maximus-damping-jpg
    Designing new Router called Maximus-plain-435htz-jpg
