Australia Designing new Router called Maximus - Page 28
Page 28 of 30 FirstFirst ... 18252627282930 LastLast
Results 325 to 336 of 357
Thread: Designing new Router called Maximus
  1. #325
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Default Re: Designing new Router called Maximus
    Hi Zorbit - The bed has an apron for doing edge work. If you can point me in the direction of an economy supplier of ATC, or aggregates I'll see what's needed. But at this level of machine these would be unheard of but maybe thats a good thing to consider.
    Just remember its a Maker, DIY, Fabber, grade machine with no machined mating surfaces so it will not achieve "commercial" class accuracy (ie machined fit parts) but it would be good to have an ATC for large scale Maker projects. Its in the Avid CNC & Shopbot class...
    Peter
  2. #326
    Jul 2018
    dum dum
    Hi All out there? Been beavering at the dwgs and more dwg checks. The column assm looks quite nice.
    Working on a machine at the moment that is too big for thermal stress relief so they are shaking it. But to give people out there some sense of what happens when you heat treat a steel table see the chart attached. Metals have a "hot strength" as the temp rises its strength decreases. Stress relief is done at cherry red which is about 1200deg F or 650deg C. At this temp it has nearly zero strength. That's why a blacksmith can bend large sections easily and steel buildings fall down in fires. So if the structure has internal stresses of which a welded structure has heaps, these can now pull and push the structure until they equilibrate. Consequently the max stress in the structure becomes the hot strength of the steel at the heat treat temp. The general rule is about 1hr per inch soak time.
    heres some hot metal working for some fun...Peter
    The other thing to consider when stress relieving is the expansion of the metal. If you have a 8ft long table it expands over 1/2" at 600degC temp (see calc attached) . So if it is constrained in any way during the process it will buckle and be useless when it comes out of the oven.
    Attached Thumbnails Attached Thumbnails Designing new Router called Maximus-coloum-assm-jpg   Designing new Router called Maximus-hot-strength-jpg   Designing new Router called Maximus-expansion-jpg
  3. #327
    Mar 2003
    Shelby Township
    I think you need a pretty big spindle to even be able to use an aggregate head on it, and the heads tend to start in the $7500 range, and go up from there. Then add the fact that they hang pretty far out the end of the spindle, so the forces are much higher. You're really talking about an entirely different class of machine.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  4. #328
    Jul 2018
    dum dum
    Hi Gerry - I agree an aggregate adds a level of complexity beyond the intent of this machine. But into the future it's good to get an understanding of them so maybe it could be an option. I might even design my own aggregates.. that's a project. NEWS FLASH - sent 12Mb of stuff off for its first quote. So now I wait and do the mechanical parts detailing, like dwgs for the drive screws and couplings (and N&B's) to get away for quote... Soon start adding up the $$$$
    thats familiar I just fixed my kitchen cupboard bifold!!
    Regards to all out there - Peter
    Attached Thumbnails Attached Thumbnails Designing new Router called Maximus-door-jpg
  5. #329
    Jul 2018
    dum dum
    Hi All- ARRGGHH I've got trouble with my nuts!! I decided to start setting up P5 for its full contact analysis so brought it into simsolid and went thru the usual workflow. But it didn't like my nuts and refused to accept them as NUTS. This meant I couldn't preload them. All the bolts with holes where fine but the nuts remained an issue. So I backed down and just modelled the Z axis, same thing, so backed down further and modelled a small test coupon with all the size nuts I use. Again no good, so went and looked at a N&B tutorial no news there but I did notice that their nuts had sharp corners whereas my nuts I model with a small flat on the corners like real nuts have. So I changed my nuts to true hexes and bingo they became nuts, yeh!!
    So once modelled correctly simsolid will calculate if the connection opens up or closes (see opening image, shows the corner of the connection opening 0.12mm) , it calculates the effective zone the fastener is operating on (see the traction image, the traction area is greatest with the 8mm bolt as its preload is greater therefore its friction and contact area is greatest) and can show how far the connection has slipped. In this case there is no slippage. The nut image shows that the nuts have been identified as nuts. It also calculates the shear load and tensile load in the bolt so you can check its sized right.
    So now the plan is to go back to P5 as the nuts will have been updated when I open the file, and analyse the structural loops and figure out how each one is contributing to the deflection. First thing to do is model all the connections as bonded to establish the perfect minimum deflection then work all the connections to friction and bolted ones to compare to the bonded connections. Then it will be time to wrap up and finalise. May have to change something once the benders look at the parts... we wait for their $$$ and their comments. Peter
    Attached Thumbnails Attached Thumbnails Designing new Router called Maximus-opening-jpg   Designing new Router called Maximus-traction-jpg   Designing new Router called Maximus-nuts-jpg
  6. #330
    Jul 2018
    dum dum
    Hi All - This mornings exercise was to get the Z Axis bolts working. Here's the result. Current design is about 60% efficient. Looking at the joints they are not slipping which is good (at 100kgf applied load at the spindle clamp) the rail is opening and the top cap is opening slightly when "pushed" when pulled the screws are in compression. Will need to drill into the info a bit more to determine what exactly to do (if anything can be done that is) to improve the deflection in this loop. I've always assumed bolted assemblies to be 50% efficient if no analysis done. I definitely will place an extra screw down the sides and change from M5 to M6. More work to do. Peter
    edit - Further investigation shows the main improvement can be made by adding more bolts to the sides. So next round here we come. Peter
    Attached Thumbnails Attached Thumbnails Designing new Router called Maximus-z-axis-1-jpg   Designing new Router called Maximus-z-axis-bolted-jpg   Designing new Router called Maximus-z-axis-bonded-1-jpg
  7. #331
    Jul 2018
    dum dum
    Hi All & Sundry - I've included the second structural loop and it contributes 0.01mm to the deflection vs the Z axis' 0.07mm (bonded connections 0.08mm total) . So I need to look at the Z axis as this is the major deflection. I'll convert this one to a bolted model asap. I also included and deleted the extra support bearing and it did not change the deflection of the spindle. It did stop the z drive warping very slightly so I expect no support bearing is the go. Peter
    Attached Thumbnails Attached Thumbnails Designing new Router called Maximus-loop-2-pull-jpg   Designing new Router called Maximus-loop-2-z-drive-jpg
  8. #332
    Jul 2018
    dum dum
    Hi All- I've run the full machine bonded so now we know the relative stiffness of the three loops. The total deflection at 100kgf push and pull is 0.16mm. Our target was 10N per um. Currently the bonded machine is at 6.25N/um and will drop off as I convert it to bolted joints (maybe) . Say to 6.25*.7 = 4.3N/um which is still very stiff for a router. We shall see.
    So the 0.16mm is made up of 0.07mm the Z Axis, 0.01mm the drive plate and 0.08mm the gantry and columns. Will look at the gantry when its converted to bolted to see how we can improve that. Cheers Peter
    Attached Thumbnails Attached Thumbnails Designing new Router called Maximus-loop-3-full-machine-bonded-jpg
  9. #333
    Member davida1234's Avatar
    Oct 2009
    Hi Peter,
    Is all your modeling assuming that there is no "play" in the linear bearing blocks?
    BryggaCNC.com
  10. #334
    Jul 2018
    dum dum
    Hello David - There is no play in medium or heavy preload bearings. In the simulations the bearing stiffness is modelled in critical models. Bearing manufacturers publish the stiffness of their bearings, I'm currently using 600N/0.001mm stiffness for the bearing contact. Regards Peter S
  11. #335
    Jul 2018
    dum dum
    Hello David - The modelling of the bearings also includes allowing them to slide on the rails which makes it less stiff as well and allows correct load transfer from the carriage to the rail in terms of moments & forces. Peter
  12. #336
    Oct 2009
    Hello Peter, I am certain you are aware of it but wanted to still bring it to your attention.
    You have something like a 4.5 - 5 x cantilever on the Z to the tip of the tool.
    BryggaCNC.com
