Australia Good quality Drag Chain in Aus?
Results 1 to 7 of 7
Thread: Good quality Drag Chain in Aus?
    Member Sterob's Avatar
    Jan 2007
    Default Good quality Drag Chain in Aus?
    The drag Chain that came with my X6-1500GT Router is a bit lame and am looking at fitting a more robust chain as well as larger size.
    Orignal size is 18 x 25. I have not had any luck finding a significant size bigger, only hugely bigger.
    I did see 15 x 30 but a quick calc showed they had the same cross sectional area.
    I have run limit switch cables and I want to run a Spindle lamp cable so its getting pretty tight.
    1. Anybody have a source for Drag Chain in Aus, as well as spare end pieces?
    2. Are there different versions of Drag Chain? ie they open on differnet sides? The ones I have only bend in one direction.
    Jun 2017
    Default Re: Good quality Drag Chain in Aus?
    It would seem it's not easy finding the larger one's here in Aus.....i struggled, however the ones i ended up using will be too big for your application. Hope you find something, i will keep a look out for you
    May 2015
    I've bought some of these. Service is good and shipping is fast.
    https://www.ebay.com.au/itm/AU-Black...72.m2749.l2649
    Rod Webster
    www.vehiclemods.net.au
    Jan 2007
    Thanks Rod. I'll give them a try.
    Jun 2017
    Quote Originally Posted by rodw View Post
    Looks good....i might use them for my next machine
    May 2015
    If you can't work out how to open them Youtube is your friend
    You need a small screwdriver
    Rod Webster
  7. #7
    Jan 2007
    My original drag chain was 18 x 25mm which has a CSA of 450 mm2. I found some with that link 25 x 38 mm. That has a CSA of 666mm2 so that should do the job.
