New Here prt 1500w controller - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 18 of 18
Thread: prt 1500w controller
  1. #13
    Activation process thewillow's Avatar
    Nov 2018
    Default Re: prt 1500w controller
    Yes, sorry about my terminology, or complete lack of it. What I should do is post what I'd like to do. The attached image is of the present bob. What I'm trying to do is remove it, as I believe it's broken, along with the z axis stepper motor driver. Then I'd like to replace it with a different bob and stepper drivers. So far I've managed to draw up the diagram for the drivers, but the bob has me stumped. And I really do appreciate the effort, thank you.
    Attached Thumbnails Attached Thumbnails prt 1500w controller-breakout-20board-20inputs-jpg
  2. #14
    Nov 2018
    I've loaded a photo of the bob I would like to install and a diagram of how I think it might work.
    I believe the board I was referring to is the main board, and the vfd connects to that via a ribbon cable. The 3rd shot is the main board, unless that's not the right name for it.
    Attached Thumbnails Attached Thumbnails prt 1500w controller-screenshot_20190323-180257_google-jpg   prt 1500w controller-20190301_144652-jpg   prt 1500w controller-20190323_221414-jpg
  3. #15
    Member Sterob's Avatar
    Jan 2007
    PM me your email address Paul.
    Will make things easier.
    Steve
  4. #16
    Nov 2018
    Quote Originally Posted by Sterob View Post
    Steve
    I think I might have stumbled on an answer after watching countless online videos. I only need to connect the main board to the breakout board if I want to control the spindle speed through the mach3 program. I just need to connect the 12-24v to run the bob. I believe I can control the spindle speed manually through the box mounted pwm.
  5. #17
    Jan 2007
    Quote Originally Posted by thewillow View Post
    Yep, like this:
    prt 1500w controller-new-bob-jpg
    Except you don't need the USB connection , just a 12-24v supply as shown.
  6. #18
    Nov 2018
    Yep, like this:
    Awesome, that's the reply I was hoping for. The 12-24v would be more reliable than the usb cable. Now we're cooking with gas. :-)
