Australia Starting New Build CNC, Advice needed
Results 1 to 5 of 5
Thread: Starting New Build CNC, Advice needed
    Registered broker360's Avatar
    Nov 2018
    Post Starting New Build CNC, Advice needed
    This is my first blog post of my own project and my first CNC router build, it would be great to hear advice from those who actually know what they are doing. Apologies for the mess in the photo we are getting new floors so it is a bit tight in there.
    My build so far- I initially designed the aluminium extrusion machine in Solidworks(message me if you want a copy of the design files) I sent all my dimensions and locations of machined holes to a factory in China and 12 days later $2000USD including TNT delivery it arrived. I selected a heavy duty 80x80 aluminium profile and for the gantry I have used 80x160 profile(None Chinese for the gantry). For the rails I have ordered 25mm HIWIN rails and blocks from Taiwan. The rack and reduction drive I have ordered from cncrouter parts. The spindle is a 2.2kw air cooled GML and runs off single phase. All aluminium plates have been ordered from the same Chinese factory as the extrusions who have been great to deal with all they needed was the dxf file. I will be adding a vacuum table however I a yet to find a good vacuum pump which is single phase.
    Really happy with the assembly so far as across the diagonals have only a 0.2mm variation.
    And this is where I am a bit indecisive about electronics and software. As myself and the other people who use the machine mainly operate using Adobe illustrator and have 0% machining knowledge we really would like as simple of a process that is possible to get from an open .ai document to the machine cutting any more advice on the workflow would be appreciated. Once I have the software plan down this will then allow me to order the last components etc, I'm thinking nema 34 for the motors but again any advice on this I would be thankful for.
    I know a little more about laser cutters than CNC's so I have also started a build using the same extrusions of a 3mx3m laser cutter (and 1.2 x 2.4 plasma) which I will post once they are assembled, looking for suggestions on supply of non Chinese laser tubes ideally CO2 around the 250w range and if anyone has experiance making a laser cutter in a larger size I would be keen to see it.
    Thanks!
    Attached Thumbnails Attached Thumbnails Starting New Build CNC, Advice needed-20181107_165712-jpg   Starting New Build CNC, Advice needed-frame-jpg   Starting New Build CNC, Advice needed-tim-3f-3f20180828131456-jpg
    Default Re: Starting New Build CNC, Advice needed
    Looking good so far !. I am not much help with the design side of the machine but I might be able to offer some advise on the machining side.
    If you are exporting from illustrator I assume you are just cutting 2D shapes etc ?
    Cheers
    David
    Member Sterob's Avatar
    Jan 2007
    Looks good.
    Where are you located?
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Hello Broker - Hows the build going? Peter
    ericks
    Guest
    Looking great, well done so far
