Australia Newbie to metalworking
Results 1 to 6 of 6
Thread: Newbie to metalworking
    Feb 2018
    Default Newbie to metalworking
    Hi folk,
    Total newbie here - always have wanted to get into machining of metal... and have just bit the bullet and purchased a Sieg SC-3 400 mini lathe (yet to be assembled).
    I don't know if this is the forum where I belong - as I note reference is made more of CNC machines than actual lathworking ... if I am in the wrong place, can someone kindly suggest where I should be posting.
    frats,
    Rosco
    Member Sterob's Avatar
    Jan 2007
    Default Re: Newbie to metalworking
    Hi Rosco,
    I am not sure are any spots for your machine here if you are not venturing into the world of CNC. ( I may be wrong...)
    I would suggest Googling your lathe and forum and see what pops up. Find a forum that mentions your lathe lots and go from there.
    Welcome to the metalworking world.
    Steve
    Feb 2018
    Thanks Steve, I tried to find a forum concerning lathes, and mores specifically - my Sieg lathe... without succes - hence why I am here. I cannot belive there arne't heaps of lathe or metalworking with lathe forums.... maybe I'm not trying hard enough...? Thanks for your reply.. I'll plod on with it.. maybe, even the place where I purchased the lathe from (Ausee) can suggest one.... frats, Rosco
    Jun 2010
    There are quite a few around. Metalworkforums, homeshopmachinist, hobbymachinist, ...
    Cheers
    Roger
    May 2015
    There is a few other Aussies here
    Home Model Engine Machinist - Powered by vBulletin
    Also I sometimes drop in on
    https://madmodder.net/
    Rod Webster
    www.vmn.com.au
    Apr 2014
    Well that is a pretty good lathe I find it pretty accurate to a point then I re did the slides with brass Inserts smoother cross and top slide the chuck on mine was a pain material ran true took a cut then removed and reinserted in the chuck it would run out a lot .So I could not bear it anymore and purchased a Sanou chuck very accurate one of the best $90 well spent .So I suppose I should explain a little more I needed a lathe that had forward and reverse on it as well as variable speed I do a lot of tapping so that part works fantastic .I have been machining for a long time and nearly all the lathes have right hand for longitudinal travel and left for cross slide ,but you get used to it also I have a larger lathe best left for bigger jobs .I did have a Myford for years boy I made some stuff on that little thing so all in all just have fun and enjoy it's nice to know it sitting there ready to use for those little odd jobs.
    John.
