- Australia Newbie: After help/opinions on the machine I'm looking at buying
Hi All,
I'm new to all this and was just about to purchase a LT-1212 CNC Router from Shandong Lintianzhiyuan CNC Equipment Co.,Ltd when I found this forum and thought I better get some input.
Has anyone purchased from the above company before? Is there a comparable CNC that you'd recommend instead?
I'm just a hobbyist but would still like it to be fairly accurate and looking to spend around $4000. I'm in Brisbane and would prefer to buy local (Australia) if possible, but happy to purchase from anywhere.
Please any information/guidance would be greatly appreciated. I've attached the details of the CNC Router I have been looking at below.
Thanks in advance
Tam
Technical Parameters:-
Model LT-1212
Working area 1200(X)*1200(Y)*200(Z)mm
Machine dimension 1700*1750*1400mm
Whole structure Cast-iron structure
Table style T-slot table
Guide rail Round guide rail
Driving method Taiwan Original TBI Ball screw; 1605 for X,Z axis, 2510 for Y axis
Spindle 2.2KW water cooling spindle
Spindle speed 0-24000rpm/min
Spindle Collet type ER20
Spindle diameter 80mm
Cutter diameter 1-13mm
Motors and drivers 86BYG-450B stepper motors and MA860H Leadshine drivers
Invert 2.2KW Fuling invert
Control system Mach 3 USB control system
The other part included Water tank with water mist cooling system for cutting engraving soft metal
Machine Accuracy < 0.03/300mm
Working speed 7000mm/min
Idling speed 7000mm/min
Operation language G code (plt, mmg, uoo, bmp)
Working voltage AC220V, Single Phase, 50Hz
Standard Software Artcam 2010
Compatible software Type3/Castmate/Coreldraw/AutoCADor other CAM/CAD softwares
Environment temperature 0-45℃
Environment humidity 30%-75% No coagulate water
Tool sensor Yes
Optional parts 1.Rotary axis for engraving cylinders(for example, diameter 80mm +150USD)
2.Taiwan Hiwin linear square guide rail
Re: Newbie: After help/opinions on the machine I'm looking at buying
Hi searching for similar info, I found your post...or somebody bought it . Would like to know your impression I have the same interest for this machine ...
Betcha the Mach3 is pirate.
Cheers
Roger
have you had a look at 3dtek https://3dtek.xyz
i purchased the "heavy mill" 1000mm x 1000mm flat bed router. you have to be sort of tech savvy but their is heaps of instructional information avaliable. as for a hobbyists i highly reccomend. the machine is mainly aluminium construction with a good ridgit gantry. few mods could be done but i have had great results. i mainly work with wood and acrylics.
- You may not post replies
- You may not edit your posts
Forum Rules
