Redsail RS 6090 CNC Engraver/Router Nc Studio Help
Results 1 to 7 of 7
Thread: Redsail RS 6090 CNC Engraver/Router Nc Studio Help
    Registered valleyengraving's Avatar
    Feb 2016
    Default Redsail RS 6090 CNC Engraver/Router Nc Studio Help
    Hi all,
    I have recently bought a redsail RS-6090 from hflaser.com, machine has arrived and seems to work, a bit disappointed I had to build an old windows XP 32bit machine to get the NC Studio software to run, the issue we are having is we make an "NC" g code with artcam then load file to NC Studio, the machine starts to engrave then z axis drives the end mill through the table, I don't think NC studio understands the machine parameters. has anyone set one of these up and could assist?
    Many Thanks
    Jun 2010
    Default Re: Redsail RS 6090 CNC Engraver/Router Nc Studio Help
    Post code example
    Cheers
    Roger
    Feb 2016
    :1248
    N20G91G28X0Y0Z0
    N30G40G17G80G49
    N40T1M6
    N50G90G54
    N60G43Z5.000H1
    N70G0X0.000Y0.000S30000M3
    N80G0X90.085Y63.459Z5.000
    N90G1Z-0.750F1000.0
    N100G1Y63.219F2000.0
    N110X90.246
    N120X90.085Y63.459
    N130G1Z-1.500F1000.0
    N140G1Y63.219F2000.0
    N150X90.246
    N160X90.085Y63.459
    N170G0Z5.000
    N180G0X46.205Y66.452
    N190G1Z-0.750F1000.0
    N200G1X46.351Y66.598F2000.0
    N210X46.520Y66.723
    N220X46.705Y66.823
    N230X46.902Y66.895
    N240X47.104Y66.938
    N250X47.486Y66.959
    N260X47.868Y66.953
    N270X48.102Y66.934
    N280X48.332Y66.877
    N290X48.550Y66.784
    N300X48.748Y66.659
    N310X49.056Y66.798
    N320X49.378Y66.904
    N330X49.709Y66.977
    N340X50.045Y67.014
    N350X50.348Y67.024
    N360X50.652Y67.010
    N370X50.954Y66.974
    N380X51.300Y66.899
    N390X51.796Y66.720
    N400X52.038Y66.596
    N410X52.267Y66.447
    N420X52.481Y66.277
    N430X52.676Y66.087
    N440X52.790Y66.294
    N450X52.940Y66.485
    N460X53.122Y66.651
    N470X53.329Y66.783
    N480X53.552Y66.878
    N490X53.782Y66.934
    N500X54.200Y66.960
    N510X54.619Y66.953
    N520X54.824Y66.938
    N530X55.032Y66.893
    Jun 2010
    I thoroughly despise CAM programs which generate code looking like that. The stuff is incomprehensible (to humans).
    They write:
    N210X46.520Y66.723
    I would write:
    G0 X46.205 Y66.452
    F1000.0
    G1 Z-0.750
    F2000.0
    G1 X46.351 Y66.598
    G1 X46.520 Y66.723
    That said, the code example you posted does not try to send the Z axis anywhere, other than up to Z=+5.0 and down to Z=-0.75 and Z=-1.5 , so I don't know what is happening.
    Should I assume that you are working in metric AND that you have set the machine to metric? There are no g20/g21 instructions that I can see.
    Also, I note the program starts with g91 but then goes to g90 - hardly obvious because of the revolting formatting, and a somewhat strange way of doing things.
    Ah well, forgive my snarking about the generated code. It comes with age and the hot weather we are having. :-) You need someone with more experience of that machine and SW.
    Cheers
    Roger
    Registered ggprasad_92's Avatar
    Feb 2010
    India
    Quote Originally Posted by valleyengraving View Post
    Hi all,
    Many Thanks
    Hi valleyengraving,
    I'm pretty sure that either your Artcam toolpath parameters should be wrong or should your Z Zero origin be.
    Be sure to double check the simulation in Artcam, then the Z origin zero on your workpiece.
    I'd say the safest way to test run is to set a Z origin well above the job so it will only cut air. Then observe the co-ordinate readings to assess the fault.
    Be sure to throw in some feedback
    Kudos!
    Guru
    Feb 2010
    India
    Hi Roger,
    Yes, wise words. I agree.
    Those CAM generated programs are an eye-sore if you read them through.
    And, it has to switch to G90 mode as it programs in ABS mode. The G91 in the first line was unnecessary though
  7. #7
    Mar 2009
    canada
    Quote Originally Posted by RCaffin View Post
    They write:
    N210X46.520Y66.723
    I would write:
    G0 X46.205 Y66.452
    F1000.0
    G1 Z-0.750
    F2000.0
    G1 X46.351 Y66.598
    G1 X46.520 Y66.723
    Cheers
    Roger
    What is the Post processor for the RS 6090?
    Thx Bert
