Australia Resetting z axis zero after 3d roughing....
Results 1 to 3 of 3
Thread: Resetting z axis zero after 3d roughing....
    Dec 2014
    Default Resetting z axis zero after 3d roughing....
    Hi all,
    After completing 3d roughing & changing tools for the finishing run where do I reset z axis zo to? The highest point of the 3d rough-out or the height of the original material?
    Thanks in advance for any answers.
    Member awerby's Avatar
    Apr 2004
    Default Re: Resetting z axis zero after 3d roughing....
    You need to set it to the same height it was set to originally, since all the cutting is in reference to that Z-axis value. If you set it to the height of the material and there's still some left, set it to that. If you've cut away all that material, then you've got to reconstruct where it was, by going to a part of the program with a known X/Y location and height, touching off to that point, and setting the Z axis to the value shown in the program.
    Dec 2014
    Thanks Andrew.
