I recently got my first cnc and use it with ArtCam 2018 and Mach3. I did some simple engraving and cutting pieces in flat materials and everything went smoothly. Now, I decided to try engraving on the rings.
Where can I find a tutorial how to do simple engraving on rings, so I can solve the following problems:
- Every engraving I make in ArtCam in Mach3 is mirrored (fliped horizontally)
- How can I most easily determine zero correctly on the x, y(a) and z axes?
