Want to route text for labels
Results 1 to 2 of 2
Thread: Want to route text for labels
    Member Feralbass's Avatar
    May 2019
    Default Want to route text for labels
    Hi folks
    Hoping someone can help.
    I have purchased a Chinese CNC router 3018.
    This was purchased mainly for work, routing and later laser, (making plant ID labels for machinery and equipment)(text and numbers), and also for me to learn what is good and bad for my personal build.
    The unit come with its standard program, which works in sample demo.
    I will be working in Graffolite type material (2 layer plastic) and the idea is to engrave the text and then cut out the shape.
    I have loaded Inkscape to create the vectors and Unicorn for the G code files.
    It doesn't work.
    What free programs do you guys recommend to do this work?
    Am I going down the wrong path?
    I am looking for something simple so once running, the guys in the workshop can quickly do labels as required.
    Thanks for any help in advance, cheers, John
    Member okiepapa's Avatar
    Sep 2018
    Blanchard
    Default Re: Want to route text for labels
    Feralbass,
    Which control system is on you cnc ?
    QPOWIER's Avatar
    Aug 2019
    Quote Originally Posted by Feralbass View Post
    Hi folks
    It doesn't work.
    Hi John, the application software could be GBRL. Google it and have a try. Good luck.
