Need Help! I need to mill a slot the same size as the router bit
Results 1 to 4 of 4
Thread: I need to mill a slot the same size as the router bit
    Apr 2016
    United Kingdom
    Default I need to mill a slot the same size as the router bit
    Hi All,
    I use ArtCAM and can design & mill straight forward shapes with area clearences, inside and outside profiles, etc. This one thing defeats me. I want to mill a 10mm wide slot, 30mm deep, using a 10mm router bit. How do I get ArtCAM to let the router bit just run up and down the slot until it reaches 30mm, exactly 10mm wide?
    Cheers
    Gary
    Dec 2013
    Default Re: I need to mill a slot the same size as the router bit
    Tell ArtCAM that the endmill is 9.98mm rather than 10mm, that's what I do in CamBam.
    Jim Dawson
    Sandy, Oregon, USA
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Can't you just draw a line or vector and use a profile toolpath on the line?
    UCCNC 2017 Screenset
    Dec 2013
    Gerry, that will work if you do an engrave operation.
    Jim Dawson
    Sandy, Oregon, USA
