ArtcamPro castle
Results 1 to 4 of 4
Thread: ArtcamPro castle
    Junior Member Lack96's Avatar
    Jan 2019
    Default ArtcamPro castle
    Hello!
    I have the following problem:
    I have a simple JPEG file, picturing a castle.
    I have to make out of it a relief for a coin, something like in the second picture.
    The relief will be used to make a negative for a coin press machine.
    I have tried the create relief from the bitmap, but even with a gray scaled picture the result was a very poor quality something.
    Please, can someone give some guidance, how can I make a normal relief from the bitmap?
    Other software, or within ArtcamPro.
    I don't know the professional digital coin designers use.
    Or anything else that could give me a result?
    Thank you in advance.
    Attached Thumbnails Attached Thumbnails ArtcamPro castle-castle-jpg   ArtcamPro castle-castle-coin-jpg
    Member ygorek's Avatar
    Oct 2016
    Russian Federation
    Default Re: ArtcamPro castle
    Need to draw everything from the very beginning!
    New models, and FREE models 6000+++ STL here ---> https://sz51.ru
    Jan 2019
    Hello ygorek!
    Thank you for your reply.
    So I draw the silhouettes, extrude them, give them a smooth.
    What about the trees?
    How can I make them as they are organic, and more complex then simple shapes.
    Oct 2016
    Russian Federation
    I do not squeeze out models, I draw them. If you want to achieve high quality, you need to draw each log separately! Here is my one of many works:
    ArtcamPro castle-3-800x800-jpg
    Drew a picture of each item separately! If I had squeezed this model, there would be no such quality!
    Attached Thumbnails Attached Thumbnails ArtcamPro castle-3-800x800-jpg
ArtcamPro castle
ArtcamPro castle
