touch probe and start stop switch wiring from risercard on servo board
Results 1 to 4 of 4
Thread: touch probe and start stop switch wiring from risercard on servo board
    May 2009
    Default touch probe and start stop switch wiring from risercard on servo board
    Eric, can you tell me the pin outs for the touch probe and start stop switch for the Techno pci servo board riser card?
    Member ericscottf's Avatar
    Sep 2012
    Default Re: touch probe and start stop switch wiring from risercard on servo board
    I will get this for you shortly.
    Eric Feldman - Design Engineer, Programmer
    Armor CNC - http://www.armorcnc.com Support hours: 7am thru 10pm EST, 7 days a week
    Sep 2012
    Hello,
    pin 14 is gnd
    pin 2 on the straight end connector is the probe
    pin 6 is pause on the bent end connector
    pin 8 is start on the bent end connector
    Send me an image if you want us to check it out before you power up.
    Use at your own risk and BE CAREFUL.
    May 2009
    Eric,
    Thanks.
