Roland Pix3 3-D Touch Probe Scanner
Results 1 to 5 of 5
Thread: Roland Pix3 3-D Touch Probe Scanner
    Registered witelite's Avatar
    Mar 2014
    Default Roland Pix3 3-D Touch Probe Scanner
    I have recently purchased a Roland Pix3 touch Probe Scanner. I know it is long since been discontinued, and probably goes back to
    Win 95. Any information regarding setting it up would be appreciated. I am assuming that it will only work with a 32 bit machine,
    luckily I do have one that I can run either Windows XP or Win 7 on, 32 bit. I have been told that the 9 pin serial hook-up presents problems,
    Please get back to me with any information that you have on this set-up. I can also be reached at lotec@cox.net.
    thank you,
    Witelite
    Member awerby's Avatar
    Apr 2004
    Default Re: Roland Pix3 3-D Touch Probe Scanner
    Have you tried hooking it up yet? If so, what was the problem?
    Mar 2014
    Yes, I connected it from my Scanner to my 9 pin serial port on my i-5 Desktop, installed Dr Picza v 2.7. I first went into the controller to set the pitch to .006 for both X and Y axes. A problem occurs when I go to set the Z Bottom.
    I get the following message for all 4 ports. "Com 1 not ready. Please verify that the port is valid or is not in use by another application". I change the port number in File\ Preferences.
    Thanks for your response,
    Witelite
    Attached Thumbnails Attached Thumbnails Roland Pix3 3-D Touch Probe Scanner-image00068-jpg
    Apr 2004
    Try com 2.
    Mar 2014
    I get the same message for all four ports.
