Don’t you happen to have the LBL call in LBL?
Show your program. It’ll be easier to help then
Greetings
Hello
I’ve got a problem with my old Maoh Hansen sinking EDM machine in case of LBL programming.
An example
TOOL CALL 1
CYCL DEF
LBL 1
ngfoji
LBL 0
TOOL CALL 2
CALL LBL 1 Rep 1
The machine takes tool 1 erodes everything ok
The machine takes tool2 erodes everything ok
Then it wants to use the tool 2 again
It ignores LBL 0 somehow.
Does anyone have a clue?
Thanks in advance
Greetings
Greetings
No, everything is properly, as it should be.Don’t you happen to have the LBL call in LBL?
Greetings
Show your program.
It would be easier to understand.
Or is your program strictly confidential?
Hello Hans-Michael
Write your LBL after M30 at the end of the program and call it by T1 and T2 with LBL CALL.
Gruß / Regards
CNCFanatiker
AdminCrew
Wenn wir immer das tun was wir können, dann bleiben wir immer das was wir sind.
If we always this act what we are able to do, then we always remain what we are.
I have already tried that.
The machine doesn’t know M02 or M30.
I programmed LBL after M30 when all LBL had been completed.
The machine processed the LBL with the last EL.
IT WORKS!
I wrote LBL after STOP
And now it works
Hello
I would leave Rep 1 out and only write CALL LBL 1
Regards, Armin Rauleder
<a href="http://www.ar-com.de/" target="_blank">http://www.ar-com.de/</a>
