Results 1 to 7 of 7
Thread: Stop melting my material!
    Mar 2011
    I'm trying to cut some 3/8" plastic cutting board (Building a 24" x 48" machine) but my bit keeps melting the material ruining the piece every time... I'm currently using a 1.8mm end mill. It seems to go longer without clogging at slower spindle speeds but it still clogs eventually... Maybe a larger bit?
    Any suggestions?
    Jun 2009
    Ireland
    Ï had great results with plastic board and/or perspex with one-flute 3.2 mm bit at low RPM and perfectly clean cut...
    1/8"(.1250") single flute carbide endmills for plastic | eBay
    Mar 2011
    Thank you
    I just placed an order for this bit. Thank you very much!
    Quote Originally Posted by firefoxik View Post
    Mar 2011
    THank you!
    I just wanted to drop you a thank you note about the plastic cutting bit. It worked GREAT!!
    May 2010
    What rpm did you cut at I can go as low as 5000 rpm!
    Mar 2011
    I have no idea how fast my router is turning... I really wish there was something I could buy to let me know what speed my router is running at... I have a varaible speed control but no way to know RPM speeds....
    How do you know what speed you are running at?
    Quote Originally Posted by restless1 View Post
    May 2010
    this is what i have it feeds a tach signal into my g540www.SuperPID.com - Super-PID Closed-loop Router Speed Controller
    1. induction melting
      By vallabesan in forum General Electronics Discussion
      Last Post: 02-11-2008, 09:41 AM
    2. Replies: 2
      Last Post: 02-08-2008, 05:08 PM
    3. induction melting
      Last Post: 02-06-2008, 08:56 AM
    4. What's the melting pot made of?
      By Robin Hewitt in forum Vacuum forming, Thermoforming Etc
      Last Post: 08-01-2007, 06:13 AM
    5. melting UHMW
      By Hobbiest in forum DIY CNC Router Table Machines
      Last Post: 02-09-2004, 04:42 PM
