Zen Toolworks
Page 1 of 3 123 LastLast
Threads 1 to 20 of 60
Forum: Zen Toolworks
Discuss Zen Toolworks products here!
  1. Zen spindle only runs in pulses
    Started by flaplante‎, 07-10-2017 02:38 PM
    delay, power, problem, spindle, zen
    07-18-2017, 11:40 AM Go to last post
  2. stepper motor driver amps
    Started by oldcoalminer‎, 04-09-2017 12:28 AM
    4amps, 5.6amps, amps, driver, rms
    04-09-2017, 12:28 AM Go to last post
  3. motor tuning
    Started by Rajudh‎, 12-16-2016 11:24 AM
    board, cnc, micro, motor, stepping
    12-16-2016, 11:24 AM Go to last post
  4. Arduino Hookup
    Started by fretman_2‎, 07-19-2016 05:41 PM
    connected, enable, hookup, left, noticed
    07-21-2016, 07:03 PM Go to last post
  5. Driver fuse
    Started by kjking‎, 05-15-2016 12:35 AM
    05-15-2016, 12:35 AM Go to last post
  6. 12"x12"x3" $400 Build
    Started by johnckovacs‎, 07-23-2012 08:24 PM
    4 Pages
    1 2 3 4
    01-02-2016, 08:56 PM Go to last post
  7. zen toolworks cnc with ramps v1.4
    Started by journeyp‎, 10-06-2015 12:44 AM
    axis, cnc, direction, pins, ramps
    10-07-2015, 03:42 PM Go to last post
  8. Question about zen tool works f8
    Started by Dr.Laser676‎, 05-26-2015 01:29 AM
    question, frame, tool, works, zen
    05-26-2015, 01:29 AM Go to last post
  9. Unhappy 7 by 7 Dropping pulses or ?
    Started by EWhite‎, 01-17-2014 06:42 PM
    mos, say, then
    03-27-2015, 06:03 PM Go to last post
  10. Items I need to buy not included in Zenbot 4848 kit?
    Started by 007lab‎, 01-20-2015 06:24 PM
    02-16-2015, 05:40 PM Go to last post
    01-09-2015, 06:02 PM Go to last post
  11. question about upgradea
    Started by manakawari‎, 01-01-2015 09:08 PM
    01-02-2015, 03:19 PM Go to last post
    11-15-2014, 12:07 PM Go to last post
  12. Drawer Slide CNC
    Started by jkarisny‎, 09-10-2011 01:16 PM
    4 Pages
    1 2 3 4
    08-14-2014, 05:12 AM Go to last post
  13. Stepper does not turn
    Started by dvdnhm‎, 07-26-2014 01:07 AM
    07-28-2014, 06:28 AM Go to last post
  14. Newbie with problems.
    Started by tayda‎, 06-02-2014 06:29 PM
    cnc.
    06-02-2014, 06:29 PM Go to last post
  15. Burned Out Dremel 4000
    Started by mjj‎, 05-22-2014 01:24 AM
    5.5mm, another, cor, down, except, its, maybe, mos, since, then, took, within
    05-23-2014, 04:52 PM Go to last post
  16. Zen 12x12 CNC problems with the table
    Started by sydios‎, 04-05-2014 03:38 PM
    cnc., its, smo
    04-05-2014, 03:38 PM Go to last post
  17. Correct Stepper Motor Driver Board Switch Settings
    Started by jmsiefer‎, 12-13-2013 07:35 PM
    down
    01-27-2014, 12:25 AM Go to last post
  18. mach3 setting for TP6560 (7x7 kit)
    Started by joexusun‎, 12-18-2013 01:12 PM
    01-24-2014, 05:56 AM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 7 users browsing this forum. (0 members & 7 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
