| Yeager Automation Discuss Ya controller software here. |
I pocketed a piece of alum the other day, I used deskcnc and ran it on ya. The problem is that the cut out was .050 to small, I check the g-code and didn't find a error, I check the machine my doing a incremental jog once again it was on the money in both the X and Y. What could have cause the error in the cut? I really thinks it's a YA bug and one have this happen?
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com |
| If you checked the code, maybe the cutter was smaller than you thought, or pushed off (seems unlikely it would be that much, though). Did you use cutter comp and maybe offset it the wrong way?
__________________ Software For Metalworking http://closetolerancesoftware.com |
| Nope that's the obvious and the cutter was right on. I even re-ran the file and still got the same result, the only thing I did not turn on was constant vectoring.
| Can you force the error larger or smaller depending on the size of the pocket? If you post your file, we could maybe backplot it for a second opinion. I guess we'd need to know the part dimensions, too.
| Okuma LC-20 Threading problem | Gunner | Machine Problems, Solutions , Wireless DNC, serial port | 13 | 12-13-2011 11:11 PM |
| Ballscrew Basics | Swede | Linear and Rotary Motion | 94 | 09-06-2011 07:23 PM |
| Stepper RPM and Accuracy Question. Please Help! | David Bord | Stepper Motors and Drives | 3 | 05-25-2005 03:27 PM |
| CNC gantry Machine shows problem | Alex S.A | Machine Problems, Solutions , Wireless DNC, serial port | 15 | 04-25-2005 04:02 PM |
| Fadal VMC4020A axis problem | cwww | Machine Problems, Solutions , Wireless DNC, serial port | 16 | 12-02-2003 12:07 AM |
