| Yeager Automation Discuss Ya controller software here. |
| Don From the main screen press ALT-S to get to the setup screen... then down arrow three times to "unit, label, jog and F/R settings"... press enter to open this screen. Now arrow down to Slow jog settings and press enter to edit the required axis. esc back to main setup menu and down arrow to save settings... enter to accept and esc once more back to the main screen. HTH regards Gary
__________________ embrace enthusiasm to accomplish the task Gary Davies... www.durhamrobotics.com |
| Thanks, I have things running pretty well now. I really like cncpro. The only thing I wish it had was a way to get a file in a diffrent directory other than in cncpro\gcode or maybe a:\. I have to get out of cncpro to load a new file. Thanks the help Don C. |
| You ask and it shall be delivered... Alt-F for the file menu, arrow down to "Create or Edit G Code File" Now in the editor... Alt F for the File pull down menu, down arrow to open... you now have a DOS file/directory screen Use the tab key to switch between windows and now you can load files from anyware on your system. Alt-f to save the file to cncpro\gcode from the editor. NOTE: to be able to load the gcode file into CNCPro it must have been saved with a .txt extension and direct disk access must be enabled in the cncpro.exe properties regards Gary
| TurboCNC and KCam3 a lost cause? | Davedbq | TurboCNC | 17 | 04-27-2005 04:03 AM |
| need help fet3 driver motor is choppy and slow at low steps per inch | mike10 | Stepper Motors and Drives | 7 | 01-02-2005 03:41 PM |
| motors won't slow jog | gv71 | Gecko Drives | 9 | 11-04-2004 08:05 PM |
| It's me again..........with this jog file..... | Darc | CamSoft Products | 2 | 10-26-2004 04:47 PM |
| Softlimits and Jog | HuFlungDung | CamSoft Products | 2 | 03-08-2004 05:28 PM |
