Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Yeager Automation
Yeager Automation Discuss Ya controller software here.
Old 01-22-2004, 09:05 AM
ljoe1969 is on a distinguished road
Ace Converter G-code Question
ACE CONVERTER DOESN'T PUT LINE NUMBERS IN THE G-CODE IT PRODUCES.
ANYONE KNOW OF AN EASY WAY TO PUT THEM THERE?
Old 01-22-2004, 10:47 AM
ger21's Avatar
http://www.cnczone.com.com/autonc.htm
Old 01-22-2004, 12:15 PM
balsaman's Avatar
balsaman is on a distinguished road
Re: Ace Converter G-code Question
Are you sure? I thought there was an option to do this when converting.... I will get back to you.
Eric
I wish it wouldn't crash.
Old 01-22-2004, 12:18 PM
balsaman's Avatar
Check off "Generate Block Numbers" in the dialogue box when converting.
Eric
TurboCad 6 vs 10.2 with Ace Converter goodeye TurboCAD/CAM 7 11-27-2007 03:59 PM
parametric programming Karl_T CamSoft Products 21 05-24-2005 03:58 PM
0,0,0, UCS, and Ace JW Peters Autodesk Software (Autocad, Inventor etc) 6 04-11-2005 08:02 PM
3phase servo retrofit whiteriver Servo Motors and Drives 35 02-06-2005 10:27 PM
Tool Change WOODKNACK General CAM Discussion 10 07-12-2003 10:26 PM
