Page 2 of 2 FirstFirst 12
Results 13 to 20 of 20
Thread: Ace Convertor
  1. #13
    Registered WOODKNACK's Avatar
    Mar 2003
    Maine
    Ya i have that but it it limited .
    My little piece of the web!
    http://users.adelphia.net/~wjdupont
  2. #14
    Apr 2003
    UK
    Woodknack, if I remember correctly, you are using turbocad? If so, if you use TrueType fonts, they can be exploded so they can be read by Ace - I think you will need to explode them twice, then Ace will cut them as a bunch of G01's. It's worth spending some time playing around.
  3. #15
    Gold Member
    Mar 2003
    Hi Everyone,
    Just got my machine running a couple days ago and have made some drawings (TurboCad) to experiment with. Sometimes when I use ACE Converter I get nothing in return. File is there but zero bytes. I have played with the settings and read all I can find about it but no help. Any one else have this problem?
    Thanks in advance.
    Marv
  4. #16
    Apr 2003
    UK
    You must make sure you save your drawings as Autocad v12, or Ace will do all kinds of strange things! Can't say I've had a file size of zero though?!
  • #17
    Gold Member
    Mar 2003
    Thanks Kong,
    I'll try that. I have been saving them as DXF files and yea it's doing all kinds of strange things.
  • #18
    Apr 2003
    UK
    I'm using Turbocad 7.1, so I save as DXF, then go into the setup section on the top right, and choose autocad r12 format in there. I'm sure you knew that, but just wanted to be clear. Hope you're not offended!
  • #19
    Gold Member
    Mar 2003
    Kong,
    Actually I did not know that, thanks for waking me up. I just tried that and it looks like a real G-Code now. Thanks again.
    Marv
  • #20
    Oct 2005
    Woodnack, try outlineart. Pretty basic interface, but works for me. You can download from
    http://www.qwerks.com/allsoftware/O/3_software.html
    $20 to register
    Rgds, Lin
  • Page 2 of 2 FirstFirst 12
    1. TurboCad 6 vs 10.2 with Ace Converter
      By goodeye in forum TurboCAD/CAM
      Last Post: 11-27-2007, 03:59 PM
    2. 0,0,0, UCS, and Ace
      By JW Peters in forum Autodesk Software (Autocad, Inventor etc)
      Last Post: 04-11-2005, 08:02 PM
    3. Ace Converter G-code Question
      By ljoe1969 in forum Yeager Automation
      Last Post: 01-22-2004, 12:18 PM
    4. What to look for in a phase convertor?
      By CNC Pro in forum General Electronics Discussion
      Last Post: 10-27-2003, 10:40 AM
    5. Tool Change
      By WOODKNACK in forum General CAM Discussion
      Last Post: 07-12-2003, 10:26 PM
