Install dowl pins with flat side in backing plate, rounded other end makes easier when putting into upright
XZero CNC
Tighten Y rails down . Then put on hole cover plugs Not on X rails till last
XZero CNC
Try to lay as flat as you can in the hole but do not push in
XZero CNC
Take one of the spacers, put over plug and push down , try to keep flat . Hit it fast with hand but not hard,
XZero CNC
Trick is to have top flush with rail top
XZero CNC
Slide on blocks ,don't matter which way
XZero CNC
Put on spacer , use something flat to line them up with block M5-20
XZero CNC
