Page 4 of 6 FirstFirst 123456 LastLast
Results 37 to 48 of 68
Thread: ViperXZ 30x24 Experience Log
  1. #37
    Company Representative gio666's Avatar
    May 2008
    Blog Entries
    1
    or just put 2 nuts and 2 washer on stud and leveling would be easy
    XZero CNC
  2. #38
    May 2008
    Blog Entries
    1
    And would be better to have machine a bit higher so nothing gets caught under gantry
    XZero CNC
  3. #39
    May 2008
    Blog Entries
    1
    If not bolted to table, first run at high speed machine will be on floor
    XZero CNC
  4. #40
    Registered anthropod's Avatar
    Jul 2010
    Quote Originally Posted by gio666 View Post
    It would be better to drill the holes in table for the M8 bolts on bottom of end frame , that machine will not stay on table with out being held down. Use M8 studs and use washers to have machine level
    This certainly sounds like the way to go. Don't want the thing to fly off the table. HA!
    How deep are the holes in the bottom for the M8s?
    (I just want to figure out how long of screws I need to get when I get my washers.)
  • #41
    Jul 2010
    Does this look correct for my z axis?
    Attached Thumbnails Attached Thumbnails ViperXZ 30x24 Experience Log-image-2082282409.jpg
  • #42
    May 2008
    Blog Entries
    1
    Yes is right how you have it, you can also separate bearing blocks one more bolt hole and Z axis will be stronger
    XZero CNC
  • #43
    Jul 2010
    It's been a while since i have posted an update.
    Progress has slowed just a bit.
    Can anyone point me to some information about wiring up proximity switches to the G540? To save inputs would you wire them in parallel?
    I found this thread: G540 and proximity switches
    It goes from complex to simple.
    Thoughts?
  • #44
    Jul 2010
    Sorry for the slow progress. It's been crazy the last few weeks. I have a vacation coming up starting on the 6th. Over the ten days I plan to do my best to finish the project and make my first cuts. I have two main issues to address.
    1. I need to fix my table so it is more appropriate for my router. I did not think about mounting my router to the table. (Brain Dead Move! Ha!) I have support structures where I need to run bolts to the router. This should not be a big deal but it may require me to bolt on a piece of angle iron to the front. So I need to pickup some stuff. (I wish it was easier to get metric stuff in my neck of the woods...oh well.)
    2. Setup the Electronics. I am using a Gecko G540. Here is the part that I am confused with I am using proximity switches for the Home/Limit. 5 in all The G540 has only 4 inputs. I really wish it has 6 inputs as I would like to make/use an auto tool height plate.
    With classic physical switches, I could wire them in parallel and use less inputs. I have read that that is not the thing to do with proximity switches.. or you cant do that...I have not figured out which one it is.
    Also, some say it's best to use a separate power supply for the switches. The G540 has 10VDC out on Pin 9. Could I just use that?
    I went ahead and ordered the XZero Y sensor mounting plate/cable chain holder so I may just get the X working and worry about the Y when it comes in.
    My goal is to have the router's first cut done by Friday the 13th. :-)
  • #45
    Mar 2011
    My vote would be to get the machine secured to the table physically, then get it running without worrying about the prox switches at all until later. I have switches to install on mine, but have been running the machine quite nicely using only Mach3's virtual limits and might well never even bother with the physical switches.
    After you get the machine up and going, you can add the prox switches to the mix with the knowledge that the machine works correctly.
    Just my .02....
    Dave
  • #46
    Jul 2010
    Dave,
    Good advice.
    Just hook up the E-Stop and let it go.
    I'll sleep on it and see if I can let my self do that. Besides it's not like the thing is hard to take apart. I may just setup the x prox before I put the top on just to make it a little easier. Or may just throw caution to the wind. Thanks again.
  • #47
    Mar 2011
    Quote Originally Posted by anthropod View Post
    Dave,
    Good advice.
    Yeah, E-Stop is good to set up at first without a doubt! And go ahead and put the switches in to where you don't have to take anything apart later--just don't worry about getting everything working into the G540/Mach3 yet.
    It's not really throwing caution to the wind I don't think. It's just building from the ground up and adding one new layer (and challenge) at a time. Doing it that way when you come up upon a problem, you know what it is that you changed last and it's easier to troubleshoot....
    Dave
  • #48
    May 2008
    Blog Entries
    1
    YES prox switches are always better done last,
    XZero CNC
  • Page 4 of 6 FirstFirst 123456 LastLast
    1. Chad's ViperXZ 30x48 build
      By chadcummings in forum Xzero CNC
      Last Post: 10-25-2011, 03:40 PM
    2. XZero ViperXZ
      By gio666 in forum Xzero CNC
      Last Post: 07-02-2011, 03:46 PM
    3. Anyone have experience with a KIA?
      By petriej in forum General Metal Working Machines
      Last Post: 08-03-2007, 11:43 AM
    4. Has anyone had experience with.....
      By spunky1974 in forum Linear and Rotary Motion
      Last Post: 07-09-2007, 01:56 PM
    5. My first experience with CNC
      By NeoMiller in forum DIY CNC Router Table Machines
      Last Post: 10-10-2003, 09:08 AM
