Well, I finally have the basic structure together of the table for my Raptor32.
I purchased the legs, nuts/bolts, and corner brackets from George (parts in blue).
I purchased the 2x2" square tube sections from
Allmetalsinc.com as their prices were the best I could find online. Also, they offered a more precise cut to length that enabled me to receive the tubes cut to the exact length I needed all within 1/32"! I also decided on getting the 1/8" thick wall tubes as that would add weight and rigidity to the table.
the tubes came in right on spec. Thanks All Metals! All I had to do was drill the 3/8" dia holes to match up with the corner brackets from George. I used a 13/32" drill bit after finding that the 3/8" bit made alignment of multiple holes a nightmare.
The following pictures show a "dry run" assembly of the table. I plan on getting the square tubes powder coated, but I wanted to make sure everything fit first. I engraved letters on each tube end so that I could re-assemble the table in the same way after powder coating.
I only found one issue with the brackets from George. The inside corner bracket does not allow enough room for both of the inner bolts to get their nylon self locking nuts on. You can get one nut on, but not both. See the arrow on the 3rd picture. the solution was simple. I ordered low profile nylon locking nuts from Mcmaster.
I intend to build a 80/20 enclosure around this machine and needed to make my table slightly larger to accomodate the enclosure resting on the table free and clear of the machine and the Y axis wire carrier. This caused the machine mounting points (on the bottom of the machine end plates) to not match up with the slots in George's inner corner brackets. My solution was to add a 1/4" thick alum plate on each end of the table (pics 4 and 5) that tied everything together and allowed me to bolt the machine down with some flexibilty as to exact placement.
I plan to build a plywood shelf to rest in the lower brackets for sandbags and/or extra materials.
Basic dimensions of the table are 57" x 39" x 28" high.
So far, I'm extremely happy with the table. The corner brackets are very well thought out (with that one exception) and when you bolt everything together make the table a solid rock to compliment the Raptor going on it.
