All points are valid. One thing to remember is that if the z axis is flexing or vibrating then there is a issue with that axis, either loose rails and bearings or more likely in this case, the cutting loads are too high for the rigidity of the machine. The Xzero machines are very good sturdy machines, but like all machines they have structural limitations, push them too hard and something will give, resulting in flex and vibration that translated into the workpiece. Z axis flex will not be negatively affected affected by a rigid table, the entire system benifits
LinkBack URL
About LinkBacks
