Page 3 of 13 FirstFirst 123456 ... LastLast
Results 25 to 36 of 153
Thread: Viper-X2 40x60 Build
  1. #25
    Jan 2010
    3 phase
    I think you will need a 3 phase input to get the 300hz
    Quote Originally Posted by pencil_&_paper View Post
    I thought this might be helpful for others that need to buy an inverter for their spindles.
    While I was waiting for my table-top, I noticed that the output of my inverter (0-240Hz) was lower than the Base Frequency of my Teknomotor spindle (300Hz). I read through the inverter manual and here's what it said:
    "The BASE FREQUENCY determines the V/Hz ratio by setting the output frequency at which the drive will output full voltage to the motor. In most cases, the BASE FREQUENCY should be set to match the motor's rated frequency."
    That means to get full RPM from my spindle, I would need an inverter that outputs 300Hz. Just to confirm that I would need a different inverter, I emailed the application engineers at AC Tech and they confirmed I would. Here's my email to them along with their response.
    Model: SM230S
    HP: 3
    KW: 2.2
    Manual: SM01
    S/N: 13046426364801134
    Spindle: Teknomotor 2.0kW C41 Series
    Type: 41470168
    Base Frequency: 300
    Base RPM: 18000
    Product guide:Catalogue, Teknomotor
    The SM230S has an output of 0-240Hz, whereas the spindle has a base frequency of 300Hz. Does the inverter need to provide an output of 300Hz if the spindle base frequency requires 300Hz?
    To get full speed out of the spindle motor you will need a drive that has a 300Hz output. The SMVector would be one drive, it has an output up to 500Hz.
    Regards,
    Applications Engineer
    Lenze Americas
  2. #26
    Mar 2011
    Nah--you can have single phase input with three phase output with most of the small inverters like you need to drive this spindle. I run 220 single phase in with 300hz max three phase output on mine.
    Dave
  3. #27
    Jan 2011
    Line Reactor For Teknomotor Spindles
    A sales manager for Teknomotor spindles has recommended that a line reactor be used with these spindles. This might be useful for others that own Teknomotor spindles. Here's the email I received from them:
    "The motor has 12 months warranty from the date we ship it out.
    Do you have a line reactor connected between the motor and the VFD?
    We strongly recommend that you install a line reactor between the motor and the VFD if this was not already installed by the OEM.
    If it is a warranty issue the spindle will fail in the first hours of operation.
    Call me for any questions you might have.
    Thanks for choosing Teknomotor."
    Best regards,
    Sales Manager
    I wasn't familiar with what a line reactor is, so I found a good article that describes their operation:
    Line Reactors and VFDs
    In short, line reactors extend the life of the motor and drives by:
    * Harmonic frequency attenuation
    * Current-limiting protection for the motor
    * Attenuates EMI (noise produced by the system)
    * Captures transient voltage spikes
    * Reduces motor noise, and reduces damage to the stator windings
    * Reduces motor temperature up to 20 degrees (double the life of the motor)
    * VFD protection from current
    Mike
  4. #28
    Dec 2007
    I think I'd be concerned that the sales manager states without a conditioning filter the spindle will fails in the first hour(s)!
    That's a most unusual response I would think?
    This indicates the equipment isn't up to the usual required specs per receiving/generating EMF/EMI.
    cheers,
    Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
  • #29
    Jan 2011
    Hi Ian,
    Thanks for the head's-up. I don't think that's what he meant, even though it was worded strangely. Usually with anything electronic (esp. Integrated Circuits), if it's going to fail it will usually fail after the first few uses unless it's abused. In some cases the electrolytic paste in capacitors can dry out over time, or a PCB could be dropped and fractured, etc etc...
    I think he was trying to say that if there's a warranty issue, it will usually show up in the first few days of usage. He didn't try selling me any of his products, however, I will for sure be using a $50 line reactor with a $1400 spindle. It's a small price to pay to have your equipment last twice as long.
    "The bitter taste of poor quality lingers long after the sweet smell of a cheap price disappears." -Ain't that the truth.
    Mike
  • #30
    Feb 2011
    If you dont mind me asking where are you getting one for $ 50.00 ? I have the same spindle and need to get one.
  • #31
    Jan 2011
    Hi Ven0r,
    I'll be buying an VFD with the line reactor (filter) built in. I don't advocate any specific product, but try Ebay and search for "Fuji Inverter" for instance. I'll probably spend $300 to $600 on an inverter. Make sure you cross-reference the model number and get all the features you need, especially the base frequency (Hz), kW, and 1 or 3 phase input/output to match your spindle. I'll be buying one that is NIB, new in the box.
    Hope this helps you out a bit.
    Here's some VFDs at a good price:
    (Look at model number: FM50-203-C, or scroll down to the CV7300 Series AC Drives, and look at model number: CV-2003-H1) They also carry AC line reactors.
    http://factorymation.info/catalog/fmcat_acdrives.pdf
    Mike
  • #32
    Company Representative gio666's Avatar
    May 2008
    Blog Entries
    2
    The line reactor is more for the inverter to make sure clean power and not to get spikes.
    What he meant about spindle failing is,if the spindle fails it mostly with in couple hours of using first time you would know if it has problems,
    XZero CNC
  • #33
    Jan 2011
    Getting Started With The Table-Top
    If you have your M6 hex screws and ball-spring T-nuts, you're off to the races. I started the table-top with the first length being flush with the front of the machine, and it worked out great.
    It can be a bit time-consuming putting in the nuts and lining up the table top with them, but the whole process won't take you more than 45 minutes. I used a small level to make sure the first piece was perfectly flush with the front of the frame, and then used it again for lining up the edges of each new piece.
    http://www.youtube.com/watch?v=2_PRKfMrMfw]Getting Started With The Table-Top.AVI - YouTube
    Mike
  • #34
    Jan 2011
    Ten Easy Pieces of Table-Top
    I took 5 minutes and made double sure that the first piece was exactly flush with the front frame, and after that, each piece was a breeze to put on.
    Mike
  • #35
    Jan 2011
    Finished Table-Top
    When I finished tightening down the table-top, my first corner-to-corner measurement was just over 1/8-in. off, and I noticed there was a middle piece of table-top that had a 1mm space where it butted up against the previous piece.
    I took that piece out, turned it around (space pointing away from cnc), and put it at the very end. I then loosened and slid all the remaining pieces back into place. When I measured corner-to-corner the 2nd time after getting rid of the small space, I was within 1/32-in. of perfect square on both sides.
    http://www.youtube.com/watch?v=Nc10SZyJ56s]The Finished Table-Top.AVI - YouTube
    Mike
  • #36
    Jan 2011
    A Few More Photos of Finished Table-Top
    The XZero table-top was very easy to put together. The biggest part was waiting for the T-nuts and screws to be delivered. Now that the table-top is completed, I'm just waiting for my 8-inch Z-axis from George. Maybe I'll mount my motors in the meantime.
    Mike
  • Page 3 of 13 FirstFirst 123456 ... LastLast
    1. New: Baby Viper 60
      By Larken in forum Viper Servo drives
      Last Post: 11-20-2012, 07:53 PM
    2. Newbie- Viper 950 VMC - Communications
      By grttt3 in forum General Metal Working Machines
      Last Post: 03-11-2011, 04:29 PM
    3. New 300 Khz Viper drives
      Last Post: 04-07-2010, 09:14 AM
    4. viper or gecko's?
      By diyengineer in forum Servo Motors and Drives
      Last Post: 03-11-2010, 07:52 PM
    5. Need Help!- Viper 200 warning led, what does it mean?
      By freak_brain in forum Viper Servo drives
      Last Post: 03-28-2009, 09:43 PM
