Proximity Sensor Locations
Results 1 to 3 of 3
Thread: Proximity Sensor Locations
    Oct 2015
    Default Proximity Sensor Locations
    Hi All,
    Hoping to get some guidance regarding the proximity sensor locations. The only two obvious one's i can make out are on the Gantry supports.
    Where do the rest go?
    Jul 2007
    Default Re: Proximity Sensor Locations
    There's slots on the z axis and x axis plates that will fit the sensors. They're the only parts with large slots
    Jun 2007
    canada
    for the X its on the gantry upright, using a screw in a t slot as the pickup point. so, 1 sensor, and 1 (home) or 2 (each end hard limit) pickups.
    for the y and z its done a bit odd. they y (gantry cross) theres is meant to be 1 or 2 sensors on the back plate that pick up the aluminium moving y saddle/ ball nut mount. one sensor for each end. this works. realistically, you just need one sensor for home, and then use soft limits.
    the z is the same as the y, but its got one switch meant to pick up the z saddle at the top (home).
